RNS-E Installation into a B5 RS4
JonnyX
Post by JonnyX » Fri Feb 08, 2008 11:08 am
http://home.comcast.net/~mtaylor68/rnseinstall.htm
Slightly less rare than rocking horse <beep> and hens teeth.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
PetrolDave
Post by PetrolDave » Fri Feb 08, 2008 11:21 am
g60bv wrote:which head unit is the one to go for. they all seem to have slightly different numbers and seeing as there close to 500 quid, i cant afford to get the wrong one.!
You need a 4B0 035 192 P - that's a European model RNS-E for a C5 A6, which is the closest fit for a B5 A4/S4/RS4.
Try looking here for part number info:
http://www.navplus.us/forum/viewtopic.php?t=2
AdamS4
Post by AdamS4 » Thu Feb 14, 2008 10:20 am
TDiAvant wrote:No, trying to complete a dash transplant would be a massive job, and I don't think it would fit.
To retrofit fit RNS-E into your car, would require the following parts
Double Din Centre console
Double Din Cage
Double Din Air Con unit (I think you could get one form ebay)
Double Din gearstick surround
Double Din ashtray (Not required if you don't smoke)
Audi Navigation Unit (A6 Version)
Wiring harness with can-bus
GPS Antenna
Switches (hazard waring etc)
It's not a massive job and an be easily complete 4-5 hours
Is that the same for the facelift ?
JonnyX
Post by JonnyX » Thu Feb 14, 2008 10:26 am
Yes, if your facelift is single DIN (i.e. concert stereo)
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
AdamS4
Post by AdamS4 » Thu Feb 14, 2008 4:41 pm
Mines like this...
JonnyX
Post by JonnyX » Thu Feb 14, 2008 5:46 pm
That's concert which is single DIN
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
Jesper Rs4
Re: RNS-E Installation into a B5 RS4
Post by Jesper Rs4 » Tue Aug 24, 2021 8:43 pm
Hi,
I have some problems with my rs4 b5 / RNS-E setup,
i would like to get the DIS to work, does anyone know what pins i need to connect my canbus H/L from rns to kombi? is it grey connector pin 5 and 6?
regards
jesper.
Using Tapatalk
Return to “Electrical”
