Engine Stand - Holding an RS4 engine
Guys, I bought an engine stand from Machine Mart and just trying to work out where to actaully attached it to!
Dont suppose anyone has a picture of an S4/RS4 engine on a stand?
RE: Engine Stand - Holding an RS4 engine
i use them - remove the the clutch and flywheel and use the bell housing bolts
http://www.MRCtuning.com
Re: RE: Engine Stand - Holding an RS4 engine
God dam, I knew the solution was stairing me in the face!Doug_S2 wrote:i use them - remove the the clutch and flywheel and use the bell housing bolts
Thanks Doug ...
- confusionhunter
RE: Re: RE: Engine Stand - Holding an RS4 engine
mee too... Ive got one block on the 450kg version of that.... like wise the clutch and flywheel have been removed....
Mark.
I've got a rs4 engine on one and a rs6 engine on the other !!!!
Unit 20
0151 3366888
0151 3366888
Blue_Thunder
- Top Gear
Re: RE: Re: RE: Engine Stand - Holding an RS4 engine
Sounds like the perfect excuse to build the world's first twin engined RS!!!!grizz wrote:I've got a rs4 engine on one and a rs6 engine on the other !!!!
Maybe it was just dirty and needed a cleanderdle wrote:OK..so why is the engine out of your car?
What mods are in mind....car not fast enough for the Isle?
Paul
I will post more when I decide what route to take, but I am fitting some nice strong rods in anycase which might give some indication
As for fast enough, it can never be fast enough! can it?
