RNS-E Installation into a B5 RS4
g60bv
Post by g60bv » Wed Feb 06, 2008 6:03 pm
MRC TUNED 480BHP . -SOLD 1.9TDI AVANT 215HP. HYDBRID TURBO. SMOKING
TDiAvant
Post by TDiAvant » Wed Feb 06, 2008 6:39 pm
NO, that will only fit the B6 & B7 model A4's(2001 and later)
PetrolDave
Post by PetrolDave » Wed Feb 06, 2008 7:55 pm
You need and RNS-E for a C5 A6 - it will have the prefix 4B0 not 8E0 (an 8D0 version of the RNS-E was never made).
g60bv
Post by g60bv » Wed Feb 06, 2008 9:23 pm
this seem like a massive head ache
:bash:
g60bv
Post by g60bv » Wed Feb 06, 2008 9:27 pm
i'am probably better off finding a 2001 a4 or a6 and doing a dash transplant....?
TDiAvant
Post by TDiAvant » Wed Feb 06, 2008 11:03 pm
No, trying to complete a dash transplant would be a massive job, and I don't think it would fit.
To retrofit fit RNS-E into your car, would require the following parts
Double Din Centre console
Double Din Cage
Double Din Air Con unit (I think you could get one form ebay)
Double Din gearstick surround
Double Din ashtray (Not required if you don't smoke)
Audi Navigation Unit (A6 Version)
Wiring harness with can-bus
GPS Antenna
Switches (hazard waring etc)
It's not a massive job and an be easily complete 4-5 hours
g60bv
Post by g60bv » Thu Feb 07, 2008 10:41 am
ahh. that does n't sound too bad like that. so if find a 2001 a4 in a breakers. i shoud get all the center console and all the switches and some radio wiring. then go from there. thank you TDiAvant.
ian
TDiAvant
Post by TDiAvant » Thu Feb 07, 2008 11:38 am
Don't take any of the wiring, all you need is one of these iso to quad lock adapter with can-bus
g60bv
Post by g60bv » Thu Feb 07, 2008 11:54 am
holy hell. whats that madusers head! what does the can-bus do?
TDiAvant
Post by TDiAvant » Thu Feb 07, 2008 1:14 pm
can-bus is the communication for the car. The infotainment can-bus which is used for the navigation, gives information like ignition on/off, lights on/off, time, speed (A3, A4 B6/B7) information to the DIS, communication to the phone system. If you don't have can-bus then the RNS-E will not work. The adaptor show able is just plug and play, but my guess is the diagnostic wire is missing in your ISO connectors so you need to connect the wire..
TDiAvant
Post by TDiAvant » Thu Feb 07, 2008 1:20 pm
Just so you know speed is not present on the B5 A4, so the A6 Navigation unit get the speed from the gala wire.
ChipHazzard
Post by ChipHazzard » Thu Feb 07, 2008 7:31 pm
FL Noggy S4 Avant
710N's, afterrun mod, MRC Generic Map & RS246 sticker
Kwack ZX7R & DRZ400 supermoto
PetrolDave
Post by PetrolDave » Thu Feb 07, 2008 7:36 pm
ChipHazzard wrote:this may be of interest
http://cgi.ebay.co.uk/Original-Audi-a4- ... dZViewItem
That's no good - it's for an 8E (B6/B7) A4 and won't fit the 8D (B5) A4 that g60bv has.
JonnyX
Post by JonnyX » Thu Feb 07, 2008 7:37 pm
Won't work in a B5
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
g60bv
Post by g60bv » Fri Feb 08, 2008 9:57 am
cheers guys. which head unit is the one to go for. they all seem to have slightly different numbers and seeing as there close to 500 quid, i cant afford to get the wrong one.!
Return to “Electrical”
Users browsing this forum: Majestic-12 [Bot] and 86 guests
