RS6 Air Con stuck on ECON
chris.parcell
Post by chris.parcell » Wed Feb 06, 2008 10:50 am
Can anybody help: just recently my aircon has got stuck on the econ setting (econ light on switch is constantly on). Has this happened to anybody before and if so is it easy to sort...
tartan_rob
RE: RS6 Air Con stuck on ECON
Post by tartan_rob » Wed Feb 06, 2008 1:27 pm
I suspect your air con needs re-charging. The unit has a failsafe to stop the air con being used when the gas is low. This is to stop damage.
2017 Kawasaki Z1000
2014 RS6
2014 S1
johnny11
Post by johnny11 » Wed Feb 06, 2008 4:51 pm
this is happening to me a the mo, and the compressor is constanly on, it also got rechargerd a few months ago
skiwi
Post by skiwi » Wed Feb 06, 2008 7:05 pm
might have a leak?
chris.parcell
Post by chris.parcell » Thu Feb 07, 2008 9:27 am
I have spent a bit of time looking into this and saw a message within another forum (based on A4) that said it could be a pressure sensor for condenser radiator. The cost for this part was £40 and sounded reasonably easy to fit... Has anybody heard of this? Audi wanted £70 to do a diog and said a recharge through audi would cost £100...
suffolkmarque
Post by suffolkmarque » Sat Mar 01, 2008 10:21 pm
The first procedure is to establish wheather or not the system is low on rerigerant,because ive had a few where the high pressure switch plug has had a poor connection or even broken wires around the plug,Maybe after a cam belt change)The easist way is to do a diagnostic on the climate itself to elimaniate any electrical trouble,failing that if its a low refridgerant problem its worth have a nitrogen test done or refilled with a dye. ( its worth looking through the bumber grille look for any oily or slightly dirty patches on the condensor. to see any sign of previous leaks..Quite common!
shame you wasn't a little closer to suffolk i could investigate for you!!
2003 DAYTONA GREY RS6 AVANT-MTM 500BHP + MILTEC CATBACK
Users browsing this forum: philS2 and 403 guests
