RS6 Oil Spec
RS6 Oil Spec
Please can someone tell me what spec codes Audi list in the handbook for the oil on an RS6?
RE: RS6 Oil Spec
while audi specifies that any oil which meets or exceeds vw 502 00 will fit all their cars - the rs6 is a special case, and a special technical bulletin was issued to cover it.
in the case of the rs6, only oil which conforms to vw 505 01 with viscosity of 5w40 will do. audi warn that failure to adhere to this can result in engine failure.
RE: RS6 Oil Spec
I have run Motul 5W40, Castrol Edge 10W60 and currently run 5W30. Motul was the best but as i change it every 5000kms it cost very costly
Re: RE: RS6 Oil Spec
This car shows up on Audi system as being on longlife servicing,is longlife not reccomended for this engine at all? as the 505.01 is fixed servicing oil.skiwi wrote:while audi specifies that any oil which meets or exceeds vw 502 00 will fit all their cars - the rs6 is a special case, and a special technical bulletin was issued to cover it.
RE: Re: RE: RS6 Oil Spec
The RS6 is not eligible for AVS.
the rs6 is an exception, and is on fixed intervals...
just to re-state only 5w40 is recommended by audi. in the strongest possible terms....
I use MILLERS 10W60 , This will give a much higher level of protection when the oil is hot..
Unit 20
0151 3366888
0151 3366888
it is interesting that audi specify a lower viscosity synthetic oil - i would have assumed high temps was more of an issue - not audi.
I was under the impression when they released the RS6 the approved oil was Mobile 1 which is what we use on the porsche 0w 40 VW 505 00/502 00 I maybe wrong though
03 RS6 Saloon Daytona Grey | Milltek | RS6+ Wheels | RS6 Mats | Tesco Club Card Points
yes it is, but only the 5w oil, not the 10w one.
Users browsing this forum: No registered users and 318 guests
