Esp swich problem
2.7 V6 30v biturbo - 380 bhp
santtu
Esp swich problem
Post by santtu » Fri Feb 01, 2008 3:20 am
Hello all of you!
I have some problems with esp switch. It works fine couple of days a go and now it´s dead. Abs and ECS or whatever light goes on when powering that system but that switch makes nothing when pressed. No 2 seconds or 20sek.
Had looked system with wag-com but changed nothing in there.So ESP is allways on. Is that switch really dead or what? Any ideas? Can i bypass it somehow to test it?
car is june 01 made if that makes any differense.
Thanks all for your efford on this issue!
And bofore any commands about those wheels they are only for winter tyres :oops:
IMG_1635 (Medium).JPG (126.84 KiB) Viewed 471 times
R5YUG
RE: Esp swich problem
Post by R5YUG » Fri Feb 01, 2008 10:26 am
Umm - Wag-Com - is that something about footballers wives / girlfriends?
Is the ESP light illuminated on the cluster - in normal non fault operation the traction control on setting will be reset when you turn the car off and on.
- If the light is remaining lit then it would indicate a fault with any of the contributing ESP items (normally ABS sensors) - but as you say if VAG-COM hasn't thrown up any faults then it's likely to be the switch.
To start with I would pop the switch out and using a multimeter test the connections in on / off with continuity to ensure the switch is working correctly.
HTH Guy
2012 Audi RS3 in Daytona Grey
2003 VW Golf IV R32 Turbo Deep Blue Pearl - "THE PROJECT"
1993 VW Golf Mk1 GTi Rivage Blue
1968 Karmann Ghia
neckarsulm
Post by neckarsulm » Sat Feb 02, 2008 8:11 am
There is a field in VAG COM measuring blocks somewhere that will change from ON to OFF when ESP button is pressed, could be in engine or ABS modules, or both, worth a check.
As well as R5 YUG's good advice, it could also be a loom issue so check the wiring hasn't been damaged betweem switch and ECU - probaby not easy I admit!
Users browsing this forum: No registered users and 83 guests
