Mauled an 2.5 '07 Sti WRX saloon today
tartan_rob
Post by tartan_rob » Thu Jan 24, 2008 6:24 pm
Not so much on straight line, nothing in it 2nd and 3rd but 4th started to get the better of him.
But through a longer corner I had him. I nailed it in 4th and took a long corner quickly, he backed off and then would not pass at all.
I was surprised because they stick to the road like a shi.tty blanket and the new ones are very fast and they weight the same as a mug of coffee.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Nige_RS4
RE: Mauled an 2.5
Post by Nige_RS4 » Thu Jan 24, 2008 7:04 pm
They are still around 1500kg - which is pretty similar to what your old S4 was (1540kgs)?
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
P_G
Re: RE: Mauled an 2.5
Post by P_G » Thu Jan 24, 2008 9:37 pm
Those scooby's are getting a bit lardy aren't they? Must be all that quality materials they put in them now.
Norrs2
Re: Mauled an 2.5 '07 Sti WRX saloon today
Post by Norrs2 » Fri Jan 25, 2008 8:59 am
Tartan_Rob wrote:Not so much on straight line, nothing in it 2nd and 3rd but 4th started to get the better of him.
Would have thought in a straight line you would have buried it Rob???!!!!! It's got 300bhp?
B5 RS4 - Santorin Blue Pearl
B7 Brakes
MRC Custom Re-Map
Loba Camshafts
Wagner Downpipes
Miltek Cat Back SS Exhaust
1988 Pearl White MB Ur quattro (Genesis)
tartan_rob
RE: Re: Mauled an 2.5
Post by tartan_rob » Fri Jan 25, 2008 9:10 am
Perhaps it was tuned..? The RS4 felt quite quick yesterday and I was surprised. Below 5k I would have expected but but over 5k I did not expect him to be there or anywhere near. But one-the-less, 2nd and 3rd gear there was nothing in it. In hindsight it did have a big exhaust so may well have been tuned. Even though, it was quick.
2017 Kawasaki Z1000
2014 RS6
2014 S1
RS4Molar
Re: RE: Re: Mauled an 2.5
Post by RS4Molar » Fri Jan 25, 2008 9:33 am
Tartan_Rob wrote:Perhaps it was tuned..? The RS4 felt quite quick yesterday and I was surprised. Below 5k I would have expected but but over 5k I did not expect him to be there or anywhere near. But one-the-less, 2nd and 3rd gear there was nothing in it. In hindsight it did have a big exhaust so may well have been tuned. Even though, it was quick.
Your car standard rob ?
I too would've thought you'd smash it ? Forced induction is one way of creating horsepower however cubic inches and the sound of the rs4 along with its quality build is sublime.
Go for a remap, not expensive and see the difference from standard OEM tune
2007 Phantom Black DnA tuned (UK)stage 3 B7 RS4 saloon, hotchkis arb's, H&R springs, goodridge lines, ferodo DS 2500 pads, GMG cat back exhaust system, BMC panel filter.
2005 Grey B5 A4 2.0 TFSI sedan
2000 WRC WRX turbo-210/285 (kw/bhp) atw
pippyrips
RE: Re: RE: Re: Mauled an 2.5
Post by pippyrips » Fri Jan 25, 2008 11:58 am
Don't under estimate them. Those that have owned/driven one will know what i mean.
tartan_rob
Post by tartan_rob » Fri Jan 25, 2008 12:22 pm
My car is std. I was supposed to get cats stripped out and remapped by MRC in Dec but work got busy and I could not make the appointment. Jan was supposed to be quiet but that was not the case. So hopefully in Feb I can get up there.
Does anyone have a vid of a remapped RS4 running no cats?
The scooby's should not be underestimated but was surprised by how much slower he was through the fast corners.
2017 Kawasaki Z1000
2014 RS6
2014 S1
mixja
Post by mixja » Fri Jan 25, 2008 12:26 pm
STI has almost as much torque as the RS4, so in terms of off the line acceleration, the STI will be ahead initially...STI also has much shorter gearing than the RS4 which helps in terms of acceleration...
They tested the 2.5L International Spec down here in New Zealand recently (NZ Autocar), 0-100km/h in 5.11s vs 4.62s for the RS4 back in early 2007...big difference...80-120km/h which generally tells a better story was 3.2s for the STI vs 3.0s for the RS4 (out of interest the E92 M3 ran 0-100 in 4.95s but a quicker 2.85s for 80-120)...
I duelled with an EVO X the other day, it was slow, the International Spec weighs over 1600kgs with full tank, which accounts for its tested time of 0-100 in 5.5s (80-120 in 3.4s) - NZ Autocar tested again...
I used to own an STI Spec C (1390kg kerb weight) modified to 325WHP and I must say on the track it was hard work hauling in RS4 Avants - if the Spec C was in stock trim (260WHP) the RS4 would have been quicker around the track. I was really surprised how well they went and is part of the reason I went for an RS4.
olliecampbell
Re: RE: Re: RE: Re: Mauled an 2.5
Post by olliecampbell » Tue Jan 29, 2008 10:34 am
pippyrips wrote:Don't under estimate them. Those that have owned/driven one will know what i mean.
Sorry to partially hijack the thread....
So Mr P Rips, have you taken the Audi plunge?
SR71
Post by SR71 » Tue Jan 29, 2008 11:14 am
These days with many cars in the sub 6 sec 0-60mph bracket, a far better indication of how the respective cars are going to fare against each other has to be the 0-100 mph time, or, as already mentioned, the 40-80mph or 80-120mph etc bracketed times.
If you screw up the launch or fudge a gear-change, a genuine 4.5 sec car will easily become a 5.5 sec car...
I have to say for me, the exciting part of the rev range in the RS4 is 5500+ and a remap will make absolutely no difference (IMHO) to how the car feels above this point whilst accelerating in the lower gears because by then the car is producing about 85% of its max power, we know remaps are giving ~5% gains, and you're only in any particular gear for a short period of time...
But then again the two cars represent two different paradigms...
Turbocharged Scooby with a WRC pedigree - torque is king, and the NA B7 RS4, which basically doesn't come alive until 5500rpm on the tacho and is basically a bored but de-tuned DTM V8 road car.
Interestingly, NA 4L DTM cars are artificially restricted to 470hp so our 4.2 ought to be able to produce (as mentioned before by me) >~480hp.
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
rs4v8
Post by rs4v8 » Tue Jan 29, 2008 11:36 am
RussianM3_dude wrote:You must be so proud, you beat a car with half the cylinders and 120hp less.
Sorry, but for someone who claims to own an RS4, you seem extremely quick to criticise it at every opportunity.
Why don't you log off before your dad catches you on his computer. This is me wording this politely!
Better still, can one of the mods please have a word with this guy? He's clearly a crank along with being delusional and tedious at best.
:ban: Anyone agree?
Current
'10 Nissan GT-R Black Edition, Kuro Black.
'59 Scirocco 2.0 TFSI
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'07 RS4, Phantom black saloon
'57 Clio 197
'04 Aprilia RSVR Factory. Black.
E46 M3 SMG, Alpine white
E46 320i coupe
E36 328is coupe
VW golf VR6
Screw you guys!' - Eric Cartman
GardinerG
Post by GardinerG » Tue Jan 29, 2008 11:38 am
You must be so proud, you own a car you hate because you can't afford to sell it.
rs4v8
Post by rs4v8 » Tue Jan 29, 2008 11:40 am
Ha Ha, quality!! :biggrin3:
Current
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
tartan_rob
Post by tartan_rob » Tue Jan 29, 2008 11:54 am
I love this guy...where in my post does it say I beat this guy in a straight line...? I said I could not get away from him. Can you read?
As the guys have already said, time to get off the computer before your dad catches you on it and indeed, is it not time for your nappy change?
2017 Kawasaki Z1000
2014 RS6
2014 S1
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 231 guests
