cant reset the brake warning light
as the title says I had a dodgy speed sensor and chaged that then it come up with brake test activated and I done the test, after the test the ESP and ABS light went off put vagcom back on no fault codes and I still cleared it but the big red warning sign still does not go out I toped up brake fluid just in case still no joy can anyone help??
- PetrolDave
RE: cant reset the brake warning light
Do the brake lights turn on when you press the pedal? Both bulbs blowing can cause the ABS failure to show.
Try checking the fault codes again - it's very unusual to have a warning and no codes.
both light's work there is amber warning signal for the bulbs this one is the big red warning signal yeah it is very unusual for no codes I'll have a look tonight maybe do a auto scan aswell see what it comes up with cheers
1.9TDI A6 are sh*t wrong forum
Yep, VAG-COM would hopefully come up with something. Failing that check the wear sensor wiring with a Multimeter. I have blanked mine off in the RS4 as the sensors do not come with the aftermarket pads. From time to time I get a sensor fault on the dash (similiar symbol) and nothing comes up in VAG COM to tell me.
R
R
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
still no joy checked with vag com again no falut codes but the symbol comes up with three chimes all the conectors are conected
Sounds like a voltage issue to the abs module or pressure valve in the system.
Have you checked the abs section in vag?
G
G
I'm sure it said 11v on vag com and the range is 9 to 17, pressure vale how do I check that?
Brake pedal switch? Think it's a common VAG failure.
on vag com in the measuring blocks it says bleed in the brake switch bit but no fault codes also the rear lights wouldn't work no ? mine do
- PetrolDave
Is the brake switch a dual circuit one? One for the ABS and one for the brake lights...
ok i will have a look into that the fault code did come up with switch but once i cleared it did not come back but my abs light is not on and the esp light is not on just the big warning on the dis
I have this on mine and thought I could remove the coding but I see it's for MY99 motors and not a 2001. So I have to check the wires.
Checked them and they have been bodged up by someone already. Any ideas?
Phil
Phil
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
2006 BMW M6 - GONE
faults displayed on the DIS don't creates logs in the fault memory e.g. if you have low brake fluid (you dont), this wont cause a fault vag com can read.
Have a look in the manual and double check what it could mean, if it's just brake fluid you could have a problem with the brake fluid level sensor or its wiring or possibly even the cluster. Apparently BBA Reman say this isn't unusual.
What I have seen on many later cars (inc my RS4 when it was left unusued for 3 weeks) is low voltage on cranking the engine causing the DIS to display a fault relating to the brake system which clears after a few secs of the engine running - if yours stays on while driving etc it wont be this to blame.
Good luck.
Good luck.
Nah it comes on immediatley and never goes off. When I had the pads done last week the tech said that someone had previously taped up the sensor wires so I reckon the fault likes somewhere else in the loom.
Gonna be a pig to solve as it could be either side of the fronts.
2006 BMW M6 - GONE
2006 BMW M6 - GONE
