Seeing as the weather appears to have cheered up I am going to get my ECS brakes on this week all being well.
One question I have though is the bleeding of the brakes after putting them on. I know I have to do the fronts (obviously), but do I need to do the rears too? I am not sure if air pockets can migrate along the pipes to other areas while the calipers and lines are all off?
If I am thinking to change out the fluid at the same time, would this mean I need to bleed rears as well?
Fine with sticking them all on, but have only done disk and pad changes on a car before. Done a rear caliper on motorbike but that has seperate systems for front and rears.
Fitting new calipers - bleeding?
. S4 Nogaro Blue Avant . ECS IV . RS4 handling bits . 18" Ultraleggera . AWE Boost Gauge . MRC Custom Map . 315 BHP . 482 Nm .
RE: Fitting new calipers - bleeding?
You don't have to the rear's but it would be a good idea to replace the fluid . Use a hose clamp on the flexi hose to the caliper that you are changing , this will prevent too much fluid being lost and make it harder to bleed the system .
Unit 20
0151 3366888
0151 3366888
Cheers Grizz, I was going to do all this today but the missus has nicked off in the car to go swimming GRRRR! Was there when I left on my motorbike to get a couple of new spanners for the job, came home and the car had gone.
Shame, it was a lovely sunny day today here, made use of it and went for a good ride out instead on the bike .
- mikeyquattro
- Top Gear
It's forecast snow at the weekend, so you won't be doing them anytime soon!
Tomorrow is another day
Ah double bugger! Crappy weather for working on the car, crappy weather for riding to work.
Users browsing this forum: No registered users and 60 guests
