Brake upgrade.
Nige_RS4 ran this setup for quite some time and said it was a good way forward.jeffw wrote:Ummm....not sure I'd run it like that....the disc rotor isn't designed to work with the much bigger caliper and I would imagine that heavy use would shag the B5 discs very quickly. Temporary measure only I think.
Mark
- quattrokid1
- Top Gear
so how do these compare to Porsche 996 brakes then?
My pal has just got a front and rear caliper set for his B5 RS4
He is of the opinion that the RS6 set up cant discipate the heat quick enough from its 8 piston/ 8 pads compared to the Porsches 2 pot 2 pad caliper!!
Just wondered since I havent seen anyone take this route before.
Misano red B5 RS4 710 D/V's SERVICED BY EL GRIZZMO:).... Wife's !!
Tornado red WR quattro
UrS4 saloon auto:) resurected by Unit20
Audi S3 8L Imola yellow
Audi B6 S4 Cabrio SOLD
Audi 100 2.2E SOLD
Audi 80 cabrio 2.6 V6 (SOLD)
Audi 90 quattro SOLD
Audi 100 2.2E SOLD
That's always been my concern mate, other guys will say different and could be right, but the physics of the whole scenario of 4 pistons/4pads per side never quite washed IMHO, especially for road/track use. I always have and always will be a friend of the Brembos that have been 'Porsched', plus the PF001 pads that fit the GT3 calipers are the bollox compared to 'any' of the Pagids by my experience ....He is of the opinion that the RS6 set up cant discipate the heat quick enough from its 8 piston/ 8 pads compared to the Porsches 2 pot 2 pad caliper!!
Cheers,
Andiroo
Previous :RS4 B5 (Noggy Babe), 934 GT2, 996 Cup.
WIP :to be advised.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008 **And how it died on it's arse**
Brakes
I have the 8 pot Brembo's on mine and they are superb for both track and road. I have done several track days and 3 Vmax events and they have never faded once.quattrokid1 wrote:so how do these compare to Porsche 996 brakes then?
Pads last around 10,000 miles with the aforementioned in mind!
RE: Brakes
The thing to remember regarding Porsche brakes is that they are designed to work on a Porsche. The 911 has a large mass over the rear wheels (the engine) which allows the car to run much larger brakes on the back and have a very different braking bias front to back. The 996 runs something like 60/40 front to back bias where as most front engined cars would run 85/15 or 90/10.
All of this adds up to the fact that the 911 has 4 large brakes which have a pretty balanced braking effort. A RS4/S4 B5 needs hugh front brakes to do 90% of the braking.
If you look at the brakes Porsche designed for the nearest equivalent (mass distribution wise) car in their range (the Cayenne) you'll see what I mean. This design issue is also why the 911 can afford to run cross-drilled brakes and why none of the performance upgrades to brakes for the B5 chassis supply cross-drilled rotors but use slotted rotors. Cross-drilled for show and slotted for go (or stop !) is an expression you will hear if you ask brake designers the question, just take a look at the brakes on every front engined racing GT car that has a similar mass to the B5 and you will find slotted discs.
As to heat dissipation, this is a product of the surface area of the rotor (bigger rotors are better), the area of the caliper, design of the rotor veins (if any) and how air is circulated to the brake system. A 2-pot Porsche caliper is unlikely to dissipate heat quicker than a 8-Pot Brembo caliper.
jimbo1234567
- 5th Gear
RE: Brakes
i wonder if this disc and caliper combo would be of any use on a b5 looks like theyre 8 pots? http://cgi.ebay.co.uk/Audi-A8-Calipers- ... dZViewItem
665 bhp + 586 lbft...
Re: RE: Brakes
Good point well made Jeff.jeffw wrote:The thing to remember regarding Porsche brakes is that they are designed to work on a Porsche. The 911 has a large mass over the rear wheels (the engine) which allows the car to run much larger brakes on the back and have a very different braking bias front to back. The 996 runs something like 60/40 front to back bias where as most front engined cars would run 85/15 or 90/10.
simoncotton
- 1st Gear
- tdiquattro
