No clutch!
No clutch!
I went to the RS4 this morning, it started fine but I could not select any gears!
The clutch pressure felt normal, but I was baulked out of every gear. Turn the engine off and with the clutch depressed it will go into all gears just fine. However, nothing with the engine running.
It was raining very hard on the way home last night, but I didn't go through any standing water or puddles. Not a hint of any problem yesterday and then it has been sitting in a dehumidified garage overnight.
Car has now been recovered to Audi and I am in an A6 - awaiting news.
The general provisional diagnosis is that the clutch plate has seized to the flywheel possibly due to the ingress of moisture.
The car has only done just over 6,000 miles too. I know others have had clutch issues, but I have never had any trouble at all until now other than some slight juddering after engaging first when cold. Like I say the clutch pedal behaves as normal so it is unlikely to be the servo pipe others have had issues with in the past.
The plan is for a new clutch & flywheel at this stage, but I will let you know what happens.
Any others had similar issues?
Glyn
Navarra Blue RS6 Vorsprung (C8)
Sepang Blue RS6 Performance (C7) - sold
Sepang Blue S5 sportback (B8.5)- sold
Monza Silver RS6 (C6) - sold
Sprint Blue RS4 (B7) - sold
Polar Silver RS2 (B4) - sold
RE: No clutch!
my car now has done over 60,000 km , my clutch has no problems , but i had chenged it 3 times because with only two or three trackdays it will be burned
i don't know if there is a GOOD aftermarket clutch for the RS4 or not , if there is , i will have it as soon as i can because the std. clutch is ((((RUBBISH)))) specialy in hot weather
06' Sprint blue RS4
Hi Glyn
I experienced at weekend for the first time real hard selection of the gears until the car had started to warm up. The car had been in the garage for over a week and a half without being turned over. I went for a 35 mile drive and on the return journey seemed to be okay but not smooth as it has been in the past. My car is at 7k miles.
Misano Red RS4 B8 450 PS
Phantom Black RS4 B7 444 BHP
I must be very lucky then, as i've tracked & vmax'd mine several times & to date only one slight clutch problem which appeared to be more a limiter/esp/wouldn't blow the clutch problem. Mines still perfect after 17K miles.
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
- alex_123_fra
I'd be very surprised if moisture caused your issue. Either way, they ought to replace it under warranty.
Mine has 23k miles and never had any isses. Gear selection/feel on the RS4 clutch/gearbox is one of the best I've ever experienced. The best being an NSX-R and my '03 civic type-R.
Good luck with it.
Good luck with it.
Current: C7 RS6 - Black, VW Passat CC R36 - Black, Freelander 2 - Black
Sold: 911 C4S (991) - Black, Panamera Turbo ('11) - Carrera White, Nissan GT-R - DMG, B8 S4 - Phantom Black, B7 RS4 - Daytona grey saloon, Noble M400, Golf R32, Evo VIII MR, M3, Cooper S, Civic Type-R, BMW 120D (black), Mazda 6 MPS
tartan_rob
Well I have an update, but don't have my car back.
Apparently water had got into the bell housing and caused the clutch to bind to the flywheel due to corrosion. Not sure how that could have happened. Other than driving in some very wet weather recently the car is always parked in a dehumidified garage regulated to a max 50% humidity!
Anyway clutch has all been replaced under warranty.
Whilst the car was up with the subframe off the tech noticed that the front offside shock absorber was leaking oil. This would explain the occasional knock that I had noticed from the suspension on the front near side in the past week or so - I had thought it was possibly a weak top mount. However, as I had only experienced it a couple of times I had not mentioned it. So new damper unit has been ordered that hopefully will be in on Tuesday. The service manager was not happy with the courtesy car I had been given, so took a brand new Q7 out of the showroom with 10 miles on the clock, which is what I now have on the drive.
So far I have had very impressive service from Audi Worthing; hopefully this bodes well to getting the car back well sorted next week.
Glyn
- RS4Molar
Remember to bed the clutch in, short shift and don't ride the clutch on take off. very easy to do.GlynG60 wrote:Well I have an update, but don't have my car back.
No launches. ha ha ha!!!
2007 Phantom Black DnA tuned (UK)stage 3 B7 RS4 saloon, hotchkis arb's, H&R springs, goodridge lines, ferodo DS 2500 pads, GMG cat back exhaust system, BMC panel filter.
2005 Grey B5 A4 2.0 TFSI sedan
2000 WRC WRX turbo-210/285 (kw/bhp) atw
Update report:
Got the car back today all sorted.
Overall an excellent customer service experience from Audi Worthing too.
Glyn
- quattrokid1
- Top Gear
No they wanted the Q7 back - I was surprised by how much I like the big old bus.
Nice to be back in the RS4 - boy it feels good
Glyn
Users browsing this forum: Google [Bot] and 239 guests
