got bored today...
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
don
Post by don » Fri Jan 11, 2008 10:40 am
nice work, look forward to more updates.
How well are the manifolds matched in standard form?
quattronutter
Post by quattronutter » Fri Jan 11, 2008 4:46 pm
the exhaust manifold is very poor,i have removed a good 3 mm all the way round from each mani exhaust port,should help flow slightly better,inlet doesnt look too bad although there is a fair amount which could be removed on both the head and manifold,im not going that far though
quattronutter
Post by quattronutter » Fri Jan 11, 2008 4:47 pm
the car is a pre facelift but has the later type double bolted main caps the same as diesel block :?
s4woody
Post by s4woody » Fri Jan 11, 2008 7:27 pm
have you lightened or balanced anything..or just had a regrind and new shells..
GARTH ROAD MOT CENTRE LTD
020 83353032
quattronutter
Post by quattronutter » Fri Jan 11, 2008 7:50 pm
nothing lightend and balanced,was going to lighten the flywheel but dont think il bother
lemond
Post by lemond » Fri Jan 11, 2008 7:51 pm
They all have the double bolted main bearing caps AFAIK
'91 230E Merc. Made when Germany knew how!
'99 S4 Saloon Silver. Made after it had forgotten!
quattronutter
Post by quattronutter » Fri Jan 11, 2008 7:55 pm
main stealer said only 2000my onwards came double bolted,then again what do they know...
lemond
Post by lemond » Fri Jan 11, 2008 7:59 pm
I evn think in that Audi tech guide issued in 01/98 also called self study program 198 it shows the main caps four bolted....
and the middle two are cross bolted too!
quattronutter
Post by quattronutter » Fri Jan 11, 2008 8:02 pm
bottom end looks pretty tough all helps to stop the block twisting i guess,just the standard rods which let it down
buzzard
Post by buzzard » Fri Jan 11, 2008 11:31 pm
nice of you to take the time and do the pics....
its interesting to see a project from the start and useful to know the ins and outs of a rebuild on a car that we run.
i have rebuilt a few lumps in me time but never thought about the S4 cus its so reliable...
do you have info on torque settings and is it easy to get info on tolerences and tech stuff.
keep up the good work.
S4 B5 long gone
S4 B8 Stage 2
quattronutter
Post by quattronutter » Fri Jan 11, 2008 11:40 pm
im only doing the internals so i can push more boost without having to worry about banana shaped rods,got all the torque settings etc,its a reasonably straightforward engine to work on,patience is the key though best not to rush anything on it or its engine back out again
quattronutter
Post by quattronutter » Wed Jan 23, 2008 12:01 am
pistons and new rods in,head studs in...
quattronutter
Post by quattronutter » Wed Jan 23, 2008 12:03 am
low comp gaskets and :shock: heads on,all timed up,just a mass of wiring and vac pipes to re attatch
Harper--D
Post by Harper--D » Wed Jan 23, 2008 12:31 am
Wow youve cleaned that up well! Or is it new parts all rounds? Cam covers and main block look really clean! What bhp and torque you going for? and what spec are you making it? I.e turbos, intercoolers, injectors, FP, clutch ect.
Dave.
White MK2 Golf.. Slightly modified :D
quattronutter
Post by quattronutter » Wed Jan 23, 2008 12:42 am
gave it a good clean up,loads of new bits,k04 hybrids,ported manifolds,no cats,lower compression,rods from dahlback,fmic,water/ methanol injection, as well as nitrous,already has 10 bar fuel pump and bigger injectors,was running around the 400bhp previously,no idea what it will run at with this concoction though :)
