watch T.V while yer drivin.!!!!
- TheMachine
- Location: Flying around in my ford tranny connect fixing 3-piece suites
is there a code or thing you can disable this safety feature as the t.v will never be watched otherwise, what a waste of time.......
gumball996tt
TV in motion
Hi Call Craig at www.tclsatnav.com He did a great job on mine. He lives in Sale, Manchester. He can also do Bluetooth and various other toys to enhance audio/tv in Audis
Regards
Jonathan
Regards
Jonathan
- TheMachine
RE: TV in motion
Top man awesome, thanks Jonathan
RE: TV in motion
You have to remove the gala wire from the speedo to the nav unit; is best to put a switch in the circuit so that you can chose when to bypass the signal... as the same signal is used to work out your ETA on your journey. Thats what legendary craigyb can do for you.
Present:...
Past:
Past:
- TheMachine
RE: TV in motion
ive sent an email for a price, that would be cool with the t.v on for the family whilst on the road...
Re: RE: TV in motion
there is a suggestion that there is a adaption code that allows the speed (gala) feed to remain intact. i'd be very reluctant to hack the speed signal or you lose nav accuracy.SteveH wrote:You have to remove the gala wire from the speedo to the nav unit; is best to put a switch in the circuit so that you can chose when to bypass the signal... as the same signal is used to work out your ETA on your journey. Thats what legendary craigyb can do for you.
- TheMachine
RE: Re: RE: TV in motion
hhmmmm
Now that you mention it skiwi, I think your right.
I may be wrong, but I think its only the RNS-E version that can be programmed... best bet is to ask craig for price and am sure he'll give expert guidance.
Present:...
Past:
Past:
- mattysupra
You are completely correct about the speed thingy.Ive just got it done at my local place and he has put a small switch in that i can turn on to watch the TV and it cut's the speed signal and then i can turn off when im using the nav and i won't lose any accuracy.skiwi wrote:there is a suggestion that there is a adaption code that allows the speed (gala) feed to remain intact. i'd be very reluctant to hack the speed signal or you lose nav accuracy.SteveH wrote:You have to remove the gala wire from the speedo to the nav unit; is best to put a switch in the circuit so that you can chose when to bypass the signal... as the same signal is used to work out your ETA on your journey. Thats what legendary craigyb can do for you.
Fraser
MTM Stage 2,Billi PSS9's,Milltek,MTM Bimota's
As mentioned above, Craig in Sale will do it for you by config, not switches. GALA all intact, but video signal (either from TV or the MediaPlayer he installed for me at the same time) continues uninterupted regardless. This is on RNS-E / DVD.
Old RNS-D / CD is simply a matter of plugging in a new cable to get TV-in-Motion, again without upsetting navigation accuracy. QST in Haywards Heath (Kim Collins etc) do them and I had one on a previous allroad.
Phil G
Phil G
Users browsing this forum: Majestic-12 [Bot] and 347 guests
