Show us your boost gauges !!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
arS4
Post by arS4 » Tue Jan 08, 2008 8:19 am
I like the idea of a boost gauge, but being snobbish, I really like the Defis......
When I had my Scooby, there was a device called a SECS monitor....... is there such a thing for the Audi? Perhaps in the form of VAGCOM or similar?
Dan :)
The art of diplomacy - telling someone to "Fcuk off" so that they actually look forward to the journey
Blue_Thunder
Post by Blue_Thunder » Tue Jan 08, 2008 9:21 am
I think that's what this little device (designed for the TT) does: http://www.rs246.com/index.php?name=PNp ... ic&t=66101
lemond
Post by lemond » Tue Jan 08, 2008 8:51 pm
I chucked a piss cheap one into the vent hole... I fabricated a plastic holder so I did not even bother to cut the vent. I chucked the pod away.
It is all red lit though there was an option of green or red as you get a coloured 'rubber johnny' to slip on your bulb... it appears to be heat resistant as the red stays red and the dashboard has not turned all red yet!
I wired it up to the fag lighter ashtray backlight ... problem is it has a red needle too! Still I can see when its working OK so it does the job.
I think it was something like 16 quid plus a rip off 4 quid post... sorry no pics cus I cant be arsed to go out in this crappy weather.
http://cgi.ebay.co.uk/52mm-Boost-Gauge- ... dZViewItem
'91 230E Merc. Made when Germany knew how!
'99 S4 Saloon Silver. Made after it had forgotten!
S4TAN
Post by S4TAN » Tue Jan 08, 2008 9:02 pm
Ummmm...
You torture homo's? Not sure, but I think that could be illegal.
Deus ex machina
S4
Post by S4 » Tue Jan 08, 2008 9:10 pm
anyone got like 3 running, say like a A/F and a EGT gauges.. they are well handy. I have seen 3 in the vents once.
Darren
lemond
Post by lemond » Tue Jan 08, 2008 9:11 pm
I must say I checked out the advert.. they also have 'inclinometers'.... Do they sound alarm bells when a jaxy jockey moves in close!
BRETTCOLLINS
Post by BRETTCOLLINS » Tue Jan 08, 2008 10:02 pm
arS4 wrote:I like the idea of a boost gauge, but being snobbish, I really like the Defis......
Dan :)
http://www.psi3.co.uk/index.php?act=vie ... roductId=7
this one works in audi's had one running in mine before. with the right sensors it will display everything in real time. can reset codes too. top bit of kit.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
arS4
Post by arS4 » Tue Jan 08, 2008 11:33 pm
Ahh - didn't know they did it for the Audi :)
Quite liking the other one too - but interested in where you'd mount it in the cabin.
Does VAGCOM show the real-time data? If so, my satnav/pda could provide a "portable" option...... depending on the shiny graphical user interface ;) (I'm easily impressed! :D)
Dan :)
S4
Post by S4 » Wed Jan 09, 2008 12:34 am
I see this beast has 3 gauges, right at the end... nice video.
http://www.ecodetuning.com/video/thecut.wmv
carpy
Post by carpy » Wed Jan 09, 2008 12:51 am
BRETTCOLLINS wrote:Had a custom A pillar panel made with double pod. top hole has boost gauge and the bottom has wide band air/fuel.
Brett slightly OT but any chance you can post up some pictures of your ming blue beast for me? I've always been set on Noggy or Imola but every time I see a post from you, I always think your car looks mean so it's got me thinking about Ming Blue.
I think it might be the FMIC that gives it the mean look, but would be nice to get a few pics to see what it's like overall.
Right, back to topic sorry........
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Jan 09, 2008 9:17 am
FMIC black now and new Face lift headlights with bi-xenons
MING BLUE AUDI S4
Car is on Lock down
tdiquattro
Post by tdiquattro » Wed Jan 09, 2008 12:08 pm
There isn't a Vagcom for PDA, they did a survey and there wasn't a demand.
I use a different program on my ipaq which is free but only shows the common OBD codes real time, (no boost) , I want to hack the program to choose my own look ups but havent sussed it out yet. It is superb tho, real time and it does logs, with a bluetooth OBD interface in the socket so no wires.
as I've mentioned on other posts, does my satnav (bluetooth) and all music as well.
Nigel.
Nige'
2000 silver S4 Saloon
tdiquattro
Post by tdiquattro » Wed Jan 09, 2008 12:12 pm
Oh, and I have an electronic Omori boost guage in the drivers side vent (no the centre vents) and it is the smaller one, very difficult to get hold of now, but much much neater and less intrusive.
The electronic version is easier to install as the sender is in the engine bay and just wire to the guage (no vac hose). You can tell an electronic version as the needle does not sit at zero with the power off.
Nige'
BRETTCOLLINS
Post by BRETTCOLLINS » Sun Jan 13, 2008 6:11 pm
This is my boost and Wide band AFR gauges.
The boost gauge is Blitz MD mirror drive unit 60mm and the Wide band AFR is a Dynotune 52mm unit
MING BLUE AUDI S4
Car is on Lock down
dazzer
Post by dazzer » Sun Jan 13, 2008 9:30 pm
BRETTCOLLINS wrote:This is my boost and Wide band AFR gauges.
Where did you source the pods from Brett?
