Cheers. I'll take a look in the morning.audijohn wrote:The ECU's are under the plastic covers on the bulkhead where the wiper arms come out (drivers side).
Jack
One on top of the other from memory.jackwood wrote:OK, so you need a Torx driver to get into the ECU box, correct? You pull out the flap that the battery cover is in (across the width of the engine bay) and then there is a black box on the left (looking at it from the front of the car) and the ECUs are in there?
Jack
Almost correct,jackwood wrote:OK, so you need a Torx driver to get into the ECU box, correct? You pull out the flap that the battery cover is in (across the width of the engine bay) and then there is a black box on the left (looking at it from the front of the car) and the ECUs are in there?
Jack
I'd agree that there was no loss of power, but I hated the smoother response - I didn't swap an S4 for an RS4 only to get an S4 back again! It appears that either a full reset of basic settings or a hard drive returns the full "rabid dog" performance.Ozrs4 wrote:But I must say i kinda like the "smoother" response and I feel that the power is definitely not diminished but may be that's just me.
