Tyre questions/problem
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
SLC Detailing
Post by SLC Detailing » Sat Dec 29, 2007 3:01 pm
Went to take the car out today and got a puncture. Took the wheels off and all along the inside edge there is excessive wear with the wire poking through. Checked the other side and its exactly the same. What can cause this the allignement or just the tracking? What tyre shall i go for bearing in mind funds are a little tight now, somehthing to do with this time of year. :roll:
liamwozza
Post by liamwozza » Sun Dec 30, 2007 6:41 pm
i have the exact same problem on mine ?????????
Ads4
Post by Ads4 » Sun Dec 30, 2007 8:16 pm
Had the same problem on mine....
pics wheel 006.jpg (60.81 KiB) Viewed 1157 times
pics wheel 002.jpg (41.22 KiB) Viewed 1157 times
Adam.
MRC B5 S4 Avant.
S4
Post by S4 » Sun Dec 30, 2007 9:31 pm
check that there is no play in the rack or any of the bushes.. most probably just needs the tracking done.
4 wheel tracking is a funny thing, its only as good as who does it... and what settings they use.
you have seen some of the guys in these tyre places. would you trust them.
Darren
SLC Detailing
Post by SLC Detailing » Sun Dec 30, 2007 9:40 pm
@Ads, that is axactly what my tyre's look like on mine. Do u know what the cause was on yours? Im looking into getting the allignment and camber settings etc done. Can it be to do with the car being lowered on coilovers?
grizz
Post by grizz » Sun Dec 30, 2007 10:05 pm
get your tracking done , has the sub frame been removed for any reason ???
Unit 20
0151 3366888
s4woody
Post by s4woody » Sun Dec 30, 2007 10:05 pm
when i bought that car i put the coilover suspension on.. i also fitted tire's and had a biessbarth (audi 4wheel alignment) done..
when i fitted the MTM rep alloys i had it checked again..them tire's must have done 10,000 mile by now..thats not bad from a set of budget tires..
i had the toe-in adjusted slightly so not to wear out the edges..proberbly worth checking again as you would have had the car a year in feb...so the tire's have been on since the end of aug 05..
GARTH ROAD MOT CENTRE LTD
020 83353032
Ads4
Post by Ads4 » Sun Dec 30, 2007 10:16 pm
Had the tracking done at APS on their Beissbarth but the 19" tyres had done about 4k by then. Then I took it to the ring and back (only did a few laps and mainly wet but still a long journey). The pic was after about 5.5k miles and they were Kuhmos. The front passenger tyre was leaking air like a slow puncture but the outside of the tread that I could see was still way within the legal limit. I took the tyre off to have a look and cut my fingers on the wire inside!!
I've since put 18s on with pirelli pzero tyres and done about 4k miles + track day at Castle Combe and the inside is pretty low, I had an advisory on the MOT last month. It's been pulling a fair bit to the left for a while (something the tracking at APS didn't seem to cure?) and the bearing is squealing on that side (front) so will get that replaced while it's at Doug's. I'll then take it in to Audi for another Beissbarth session...
Adam.
MRC B5 S4 Avant.
SLC Detailing
Post by SLC Detailing » Sun Dec 30, 2007 10:35 pm
Is it quite common then for cars that are set up like ours to wear the inside edges? Sorry for being a bit dim what is the toe-in?
Not sure if the sub frame has been removed for any reason, woody would be able to say.
Ads4
Post by Ads4 » Sun Dec 30, 2007 10:51 pm
See below link no2 for toe in/out description. I discussed with Doug a while back and apparently it is a common problem on these cars.
http://everything2.com/index.pl?node=Toe
Adam.
MRC B5 S4 Avant.
Blue_Thunder
Post by Blue_Thunder » Mon Dec 31, 2007 12:52 am
I seem to remember reading that the values that the wheel alignment places use are based on a list provided by the manufacturers, therefore any aftermarket suspension, etc. can affect the true required values.
s4woody
Post by s4woody » Mon Dec 31, 2007 1:02 am
blue..the guys that did my wheel alignment aint just audi tech,s..there master techs and very good friends of mine..they know what im like when it comes to my car and wont just set it up to audi spec..they check measure re-check and make sure its correct for the type of suspension..
like i said..them tire,s must have done atleast 10,000 miles which aint bad cosidering that car aint driven by miss daisy..and NO the subframe was not removed by me or the previous owner..
steve..if your tires have lasted since aug 05 i think you've had a good run with them..just replace them leave the alignment alone and enjoy..it takes about 500 miles for a set of tires to scrub in so check them..if they look like there wearing then get the alignment done..
if the car is lowered you have to toe it in so to keep the centre of the tire in contact with the rd instead of the outside edge..due to negative camber that is generated when lowering..but im talking about seriously lowered cars..my old car was hardly seriously lowered...
020 83353032
ChipHazzard
Post by ChipHazzard » Mon Dec 31, 2007 9:53 am
I had A similar thing a while back on both rear tyres, one blew out about 2 mins after i'd pumped it up and checked the pressure and the other at about 20mph in traffic (thankfully nothing serious happened) and they were PS2's IIRC. I'm currently running Yokohama's which were very reasonably priced and I'll problably stay with them when I get round to fitting a set of 18's in the near future along with various other goodies that I have waiting to be fitted
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
