ECU Fault code? Internal Control Module Memory Error
2.2 I5 20v turbo - 220bhp
2.2 I5 20v turbo - 230bhp
newsh
Post by newsh » Fri Dec 28, 2007 11:07 pm
What does this one mean? (Engine was not running hence 00513 G28)
If I just switch on the ignition and pull the codes I get the fault come up, if I clear the codes, get no faults, and then switch off and on again the fault always reappears. If I start the engine, clear the faults and restart it doesn't reappear, stop the engine and switch back on but do not start, it reappears again.
VAG-COM Version: Release 311.2-N
Control Module Part Number: 895 907 404 BA
Component and/or Version: MOTOR MRC 1
Software Coding: 0261200484
Work Shop Code: 1267356560
2 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
00513 - Engine Speed Sensor (G28)
03-00 - No Signal
newsh
RE: ECU Fault code? Internal Control Module Memory Error
Post by newsh » Fri Jan 11, 2008 12:07 am
Bump?
Mihnea? Please?
ericd
Re: RE: ECU Fault code? Internal Control Module Memory Error
Post by ericd » Mon Jan 14, 2008 7:59 pm
John,
2 possible reasons I can remember for the error were a bad earth connection or more likely an internal checksum error ( without going into grizzly details) , modified/reprogrammed devices, like all devices generate checksums for various reasons, it's usually just the sign of a 'chipped' device being present , it's possible to hide , but a lot don't bother, like Nothelle etc.
-eric
Return to “S2”
Users browsing this forum: No registered users and 130 guests
