Right, heres a question, i was wondering if i fitted 2 of these to my twin engined mini moto (1 on each carb), would it be very beneficial, i will have a 16mm venturi instead of 12mm and will get a huge jet if these are beneficial enough. All serious advice welcome!!!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0175294971
Advice needed on a sort of turbo!!!
Dave.
White MK2 Golf.. Slightly modified
RE: Advice needed on a sort of turbo!!!
"A sort of turbo"....it's just a fan isn't it? It's level of compression isn't likely to rise with increased engine revs so its effectiveness is going to diminish...if it has any in the first place. "Up to 35% power increase" mmmmm!
If you are going to increase the charge in the crankcase and therefore the cylinder...what will you do about the timing - can that be altered?
Paul
Paul
Huge Grin
If you dont "do it now" you never will.
Huge Grin
Yep! WILL BE INCREASING TIMING BY !) DEGREES AND INCREASE FUELING TO COMPENSATE FOR EXTRA AIRFLOW!
Dave.
- mikeyquattro
- Top Gear
Hmmmmm. Unless you can get them spinning at turbo speeds (which I very much doubt) then they will just add weight!
Remember, don't port it too much, my mates was unrideable due to nasty powerband!! He just kept flipping it
Tomorrow is another day
well u have an enlarged venturi to induct air better at high speed, so i presume its a high rpm engine in which case this will be a restriction. this would give you low end torque but not a lot more
Well, ive decided to buy 2! I will see how well they work and if they aint any good they can go on EBay!
Dave.
Don't forget the FMIC
- Attachments
- chasebar.gif (5.81 KiB) Viewed 568 times
'91 230E Merc. Made when Germany knew how!
'99 S4 Saloon Silver. Made after it had forgotten!
Users browsing this forum: No registered users and 83 guests
