Custom Turbo Manufacturer
Off topic chat
derdle
Post by derdle » Wed Dec 05, 2007 11:59 pm
Saabs - yes they did turbo two strokes. I'll have a word with a Saab master Tech about this to get teh low down.
Had a word with a client who deals with bikes and small motors and feels that a 2 stroke can be charged but it is difficult. Firstly, a 2 stroke motor relies heavily on the design of the exhaust system to provide back pressure to the combustion chamber. A turbo in the way will affect the level of back pressure and will need a careful redsesign of the exhaust system. Secondly, you may have to change the gaskets in the crank to cope with the extra crankcase presuure. His advice is to follow the "normal" route of bigger carb, porting and polishing and exhaust change (necessary as part of the other changes).
HTH
Paul
Harper--D
Post by Harper--D » Thu Dec 06, 2007 12:07 am
Well, atm it has a bored out cylinder, copper head gaskets (instead of paper 1's), nos, lightweight flywheel, i have highered the compression, increased the timing of the engine by 10 degrees, k&n air filter, 3 stage carbon reed valve, and a high flow exhaust and will be porting the carb out at the weekend and will fit a bigger jet in at the same time. So any1 got any ideas for bigger power, cba stripping engine again unless i have to put i stronger rod in!
Harper--D
Post by Harper--D » Sat Dec 15, 2007 11:17 pm
Just as an update, i am no longer fitting a turbo to the bugger! I am (with help from a friend) making a custom, twin engined mini moto. 2 engines side by side linked by the crankshaft working in sync (hopefully)!
When it is completed i will post up full spec!
Dave.
White MK2 Golf.. Slightly modified :D
lemond
Post by lemond » Sun Dec 16, 2007 12:44 am
How mini is this mini moto ?
Can you fit a 100cc kart engine in it?.... they have some serious power I recall
'91 230E Merc. Made when Germany knew how!
'99 S4 Saloon Silver. Made after it had forgotten!
Harper--D
Post by Harper--D » Sun Dec 16, 2007 1:10 am
Its extremely mini!!! I wana go for summat real custom thats why im doing this. Its will effectiveley be a 2 cylinder 120cc engine running off the 1 clutch and controled throttle by 1 twist grip leading to both carbs!
P.S. tried posting picture but it aint working!!
Dave.
Return to “Off Topic Chat”
Users browsing this forum: No registered users and 44 guests
