S4's and MOT's
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
dhali
Re: RE: S4
Post by dhali » Tue Dec 04, 2007 10:15 pm
MarkB wrote:Yep, mine never goes on the rolling road brake tester.
why is that then? Does it cause some sort of harm to the 4WD system? I only ask because ive taken my car to different MOT stations over the years and some say they cant test on the rollers and others have done :?
surely if the car is in neutral it cant cause any harm?
shineydave
RE: Re: RE: S4
Post by shineydave » Tue Dec 04, 2007 10:30 pm
i'm not sure, the handbook says something about avoiding suspended tows because it can damage the transmission so i figure the same applies to a two wheel brake tester.
i'm so proud, this is the first thread i've started that has gone onto 2 pages that didn't involve gimp suits and references to the Earl of Wakefield naked
spurtle
RE: Re: RE: S4
Post by spurtle » Tue Dec 04, 2007 10:39 pm
Mine failed for 'centre exhaust mount missing' which was stupid because that mount is completely redundant with a stock exhaust. Ten minute welding job sorted it out though.
RS6 Avant (C5), Daytona grey
Gone but not forgotten: S4 Avant (B5)
imolas4uk
RE: Re: RE: S4
Post by imolas4uk » Wed Dec 05, 2007 12:06 am
all audi quattro vehicles cannot be tested on a conventional brake tester that only drives the front wheels,it will destroy the centre diff
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
searider
RE: Re: RE: S4
Post by searider » Wed Dec 05, 2007 12:13 am
OSF track rod end at 100000 miles last week.
shineydave
RE: Re: RE: S4
Post by shineydave » Wed Dec 05, 2007 1:55 am
so to recap
exhaust hangers (mainly back box)
CV boots (outer)
steering tie rod bushes
rear anti-roll bar bushes
track rod ends
keep 'em coming guys
AdamS4
RE: Re: RE: S4
Post by AdamS4 » Wed Dec 05, 2007 11:42 am
Last year, failed on O/S/F track rod end
I know i need to replace the N/S track rod end for this years MOT in Jan. Fingers crossed there is nothing else.
shineydave
RE: Re: RE: S4
Post by shineydave » Wed Dec 05, 2007 11:47 am
there doesn't appear to be much that fails on S4's
surely there must be other items that are prone to wear or are we such fastidious owners that we replace things as a matter of course
KayGee
RE: Re: RE: S4
Post by KayGee » Wed Dec 05, 2007 12:21 pm
Turbos aren't MOT failures. Unless the oil seals blow!
The usual culprits interfere with our enjoyment so they get dealt with. TBBs, DVs, MAFs (for us lucky Bosch owners)., O2s otherwise mine seems very reliable. DIS you simply turn off.
The only major issue I have had was a starter motor go at 88K.
hardhitter
RE: Re: RE: S4
Post by hardhitter » Wed Dec 05, 2007 12:34 pm
Flexible brake hoses have a tendancy to start deteriorating at this kinda age (for early models).
Dippy
Re: RE: Re: RE: S4
Post by Dippy » Wed Dec 05, 2007 2:58 pm
spurtle wrote:Mine failed for 'centre exhaust mount missing' which was stupid because that mount is completely redundant with a stock exhaust. Ten minute welding job sorted it out though.
That's interesting because mine failed for this reason plus the fact that the bracket had broken at the box allowing exhaust gasses to leak. The fix was to weld a patch on the centre box and leave the bracket off because it isn't really needed. This passed the retest.
2001 Silver S4 Avant
clubsport
RE: Re: RE: Re: RE: S4
Post by clubsport » Thu Dec 06, 2007 12:39 pm
Just back from the Mot test in my 55k mile, standard 2000 facelift....straight through no reccomendations and the tester even called another of his colleagues over to look underneath as they couldn't believe how clean it was!
Quite happy with that to be fair :)
2000 B5 S4 facelift, sadly missed...enjoying the 2005 A2 TDi Special Edition though!
jb7_uk
Post by jb7_uk » Thu Dec 13, 2007 10:43 am
Near side fornt CV boot failed my last MOT, had an advisory on corrosion on rear brake discs (have since replaced both rears due to seized rear calliper carrier) but not much else. Pre-facelift '99 110k miles.
FOR SALE :cry: :
B5 S4 - 1999 (Pre-Facelift) - Ebony Black Pearl - 18" RS4 (B5) Reps - 710n's - replaced N75 - After-run Pump mod - APR Bipipe.
See Classifieds ad (HERE) for more details.
Users browsing this forum: No registered users and 85 guests
