Wiper Motor??
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
eddiek
Wiper Motor??
Post by eddiek » Mon Dec 03, 2007 8:35 pm
Wipers sometimes take on a life of their own and go about four times instead of once when you hit the stalk down and sometimes stop in the middle of the window. This happened ages ago but they started working properly and once again about a month ago but are fine now. I have heard that the switch is actually inside the wiper motor and that the motor will need replaced. Ideas? Cost for a new one? Easy to fit? :?:
CliveH
Re: Wiper Motor??
Post by CliveH » Mon Dec 03, 2007 9:18 pm
eddiek wrote:Cost for a new one? Easy to fit? :?:
about £70 quid from memory, a bit fiddly but relatively easy to fit
Clive
JonnyX
RE: Re: Wiper Motor??
Post by JonnyX » Mon Dec 03, 2007 9:33 pm
check that the nuts on the linkage are still tight. Mine stopped working once and it turned out that
the nut on the cam from the motor had undone itself.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
GardinerG
Post by GardinerG » Tue Dec 04, 2007 1:38 pm
I was just wondering if it could be the control unit, aka Wiper Relay as all control wiring for the Wash Wipe switch and motor goes through J31 - wiper relay.
Wiper stalk (switch) -> Relay (aka "control unit") -> Wiper Motor.
SunDiver
Post by SunDiver » Tue Dec 04, 2007 3:24 pm
I replaced my motor - wipers just stopped one day after a period of being "lethargic". Bought it from VagParts.
A fiddle to get it out and the new one back in but not too bad - I did it myself without referring to how anywhere - took about an hour or so I guess. Only tip is to make sure you examine how the linkage parts attach to the motor and themselves before you take it apart as there's a right way and a wrong way...;-)
GardinerG
Post by GardinerG » Tue Dec 04, 2007 5:10 pm
I had similar lethargic wipers, even on full speed; turned out to be the frame siezing up, so didn't have to replace the motor thankfully.
Keihin
Post by Keihin » Thu Dec 13, 2007 10:47 pm
I fixed the same symptoms by cleaning the "slide switch" thingy located on the wiper motor. A couple of sliding contacts that tell the engine where to stop.
davs4
Post by davs4 » Fri Dec 14, 2007 12:29 pm
Gave mine a squirt with Fospro on all linkages now sorted.
Users browsing this forum: No registered users and 90 guests
