Audi A4 S4 RS4 Radio CD Player Concert II
MarkB
Post by MarkB » Mon Dec 03, 2007 10:46 am
Would this plug straight in on my S4?
I've currently got a Concert with Bose. I don't ever play tapes so a dash mount CD could be good. I'd want it to still display correctly on the DIS.
Mark
shineydave
RE: Audi A4 S4 RS4 Radio CD Player Concert II
Post by shineydave » Mon Dec 03, 2007 10:51 am
thought 8E0 might be from a B6 model then i found this
http://www.ibiblio.org/tkan/audi/radios/
so it looks like a standard fit A4 radio/CD, would have thought it'd work, it says it'll communicate with the DIS
Dave
PetrolDave
Post by PetrolDave » Mon Dec 03, 2007 10:55 am
The faceplate on an 8D0 radio for a B5 is a different size and shape to the faceplate on an 8E0 radio - so an 8E0 (B6/B7) radio won't fit your 8D0 (B5) without modification.
MarkB
Post by MarkB » Mon Dec 03, 2007 10:55 am
I think it is from a B6 yes. I have just thought that the faceplate colour might not be right also
Mark
MarkB
Post by MarkB » Mon Dec 03, 2007 10:57 am
Was there any single DIN dash mount CD players fitted in the B5's?
If yes would they be free of the Concert volume control problem?
Mark
derdle
Post by derdle » Tue Dec 04, 2007 10:35 am
Can you not get a OEM 6 cd stacker for the boot?
Paul
RS4 in the only colour to have - Misano Red | MRC Remap | RS6+ brakes | H&R and Custom Performance Parts suspension |
Huge Grin :biggrin3: If you dont "do it now" you never will.
MarkB
Re: RE: Audi A4 S4 RS4 Radio CD Player Concert II
Post by MarkB » Tue Dec 04, 2007 10:36 am
derdle wrote:Can you not get a OEM 6 cd stacker for the boot?
Paul
I have cd stacker already. I'd just like to get rid of the dash tape player.
Mark
Philws4
Post by Philws4 » Wed Dec 05, 2007 11:54 pm
I think from memory there are certain issues with CAN on earlier models where-by the unit needs some additional cat 5 wiring and setting up.
Check with craigyb for more info.
B5 S4
PetrolDave
Post by PetrolDave » Thu Dec 06, 2007 2:42 pm
Philws4 wrote:I think from memory there are certain issues with CAN on earlier models where-by the unit needs some additional cat 5 wiring and setting up.
Early B5s with the analogue dash clock don't have an infotainment CAN bus, so if you retrofit a later Audi radio that needs CAN you have to fit a CAN emulator.
MarkB
Post by MarkB » Thu Dec 06, 2007 2:47 pm
My Car is a later facefilt with the digi clock so should I be able to fit later headunits? Obviously I'll need to make it physically fit the dash.
Mark
Return to “Electrical”
