Door Handle Trim
Door Handle Trim
Anyone else got 'peeling' trim on the RS6 door handles. Spoke to Audi and they said that the handle part of the door trim was not avilable separately? They stated that it would cost £100's to buy complete new door trims???
RE: Door Handle Trim
yep i got the same, and not covered under Audi extended warranty
This is true , i was told it's £250+vat
Unit 20
0151 3366888
0151 3366888
the coating and problem is common on audi's of this era. i've noticed it starting to peal on my car and think the way to sort it would be to strip the trim and respray with a suitable rubberised paint. otherwise it's dealer markup time....
Mine is the same on both sides. It doesn't annoy me to the tune of £250 though. I might try a breakers as I presume its a standard A6 part.
i have the same
when i pointed it out to volkspeed where i bought the car , they cut back the loose bits and sprayed it ?
cheaper than renewing the whole door panel
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
Re: RE: Door Handle Trim
It's part of the door card so you would have to fit the whole thing !Rek wrote:Mine is the same on both sides. It doesn't annoy me to the tune of £250 though. I might try a breakers as I presume its a standard A6 part.
Unit 20
0151 3366888
0151 3366888
RE: Re: RE: Door Handle Trim
I'll live with it then. If someone has some of that rubber paint, then please post where it is available.
Users browsing this forum: No registered users and 1929 guests
