I'm a reasonable guy and don't mind them doing a tonne, but this is taking the .... (please fill in the blank with a word of your choice).
What would you honestly do if this was your car/situation?
Cheers!
Grant
It is initially callibrated by me using a gps so is more accurate than the speedo, but doesn't use gps "as you drive". It is used to tell the HUD what speed ratio to use based on the speed signal. Grizz's comment re the rolling roads helps tho, even if it makes me worry more!Fen wrote:Can't be on the RR Grant - no GPS signal inside the building. Is it the tuning company I think it might be?
