Changing Gearbox & Diff Oils
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
AdamS4
Post by AdamS4 » Tue Nov 27, 2007 11:30 pm
I'm going to change my gearbox and diff oils maybe this week....
What oils do i need ?
Anyone done it and can give me some tips ? I've changed gearbox and diff oils before on other cars but not Audi's.
rikrose
RE: Changing Gearbox & Diff Oils
Post by rikrose » Tue Nov 27, 2007 11:39 pm
I think you need to see that opieoils are doing their final sale of the year at the moment, and advertising in the Classifieds.
Goodwood green RS4, previously owned by jeffw
AdamS4
Post by AdamS4 » Wed Nov 28, 2007 12:17 am
Do you know how much oil the gearbox and diff holds ?
musty1
Post by musty1 » Wed Nov 28, 2007 12:18 am
gearbox is 2.5- 3.0 litres iirc
1.9TDI A6 are sh*t wrong forum
ChipHazzard
Post by ChipHazzard » Wed Nov 28, 2007 10:17 am
IIRC it's nearer 3.5 as I did mine a couple of years back
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
am8631
Post by am8631 » Wed Nov 28, 2007 10:22 am
Adam, Im doing exactly the same mate! The oil needs to be GL 4/5 if you want to use the same oil in box the gearbox and rear diff, and the Motul Gear 300 comes recommended @ around £13 per litre.
Audi told me that I would need 4l for the gear box and 1.5l for the rear diff - from what ive read the gearbox is anything from 2.5 to 3.2 so you can make your own mind up.
You may also need a special 'bit' to get the filler/drain plugs out - cant be certain on this as ive not been under the car to have a look. But the tool was only a few quid.
The is a write up here for an A4 - http://www.audiworld.com/tech/misc.html 6th and 7th article down.
dodgydave
Re: Changing Gearbox & Diff Oils
Post by dodgydave » Wed Nov 28, 2007 10:29 am
AdamS4 wrote:I'm going to change my gearbox and diff oils maybe this week....
You'll need 3.5l for gearbox and 1.9l for the diff. Get the millers crx competetion oil. It will convert how the box feels. Much easier gear changes and better protection than the audi lard.
http://www.millersoils.net/1_Millers_r_ ... T-gear.htm
CRX 75w90 for the box and CRX 80w140 for the diff
The change is the same as on other cars but you need drive the car for a few meters and then top up the box again because of the oil cooler and pipes. Or you could also turn a wheel.
Never enough...
GrimReaper
RE: Re: Changing Gearbox & Diff Oils
Post by GrimReaper » Wed Nov 28, 2007 5:56 pm
i did mine couple months ago and stuck 3.2 ltrs in gearbox using motul gear 300. iirc you don't fill the gearbox up like conventional ones where it starts to drip out of the filler hole when you know its full. I measured out the 3.2 ltrs and added it that way. I only live 15mins from Opieoils so its ideal location plus being on here qualifies for members discount as well.
KO4's Full Bilstein suspension, MRC custom remap Dual milltek, de pre-catted & custom Decats Forge DV's H&R ARB's, 18" RS4 Reps
Cayenne calipers B5 RS4 discs PICS: http://s8.photobucket.com/albums/a4/sjy666/Audi%20pics/
JonnyX
Post by JonnyX » Thu Nov 29, 2007 10:46 am
Reaper, Did the Gear 300 make any non-placebo difference?
J
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
GrimReaper
Re: RE: Re: Changing Gearbox & Diff Oils
Post by GrimReaper » Thu Nov 29, 2007 3:49 pm
JonnyX wrote:Reaper, Did the Gear 300 make any non-placebo difference?
J
It feels pretty smooth now when changing gear also the old gear oil was hanging when it was drained. Mate is mechanic in motorsport industry and he recomended me to use this and opie oils was cheapest i saw at the time Think works out at £45 ish (with members discount for being on RS246.com) for 4 ltrs.
When fully drained i also removed diff nut since my gearbox was out whilst having the new tubbies put on i used a bit of the spare fluid to flush out any old stuff till it came through clear.
Rees4
Post by Rees4 » Sat Dec 01, 2007 12:43 pm
Have just had my gear oils changed funnily enough,bought Motul gear 300 75w-90 from opie oils. Had 4 ltrs ordered and only took a couple of days to get here. www.opieoils.co.uk
AdamS4
Post by AdamS4 » Wed Dec 05, 2007 12:04 pm
Just going through my paper work for the car and looks like the diff and gearbox oil was replaced in 2003. Mileage was 45k and its now on 87k...
Still worth changing ??
