Weird gearbox problem
slippery
Post by slippery » Mon Nov 26, 2007 10:13 pm
Hi
Hope someone can shed some light on this.
When I start my car and put in "D" it is as if the clutch is slipping.
Turn off restart everything OK. Gearbox works perfectly until I
switch off engine and same thing happens again.
Reverse is OK when I start.
Cheers Tom
abbsrs6
RE: Weird gearbox problem
Post by abbsrs6 » Mon Nov 26, 2007 10:24 pm
hi get engine and gear box memories checked and oil level in gear box cheers abbsr6
grizz
Post by grizz » Mon Nov 26, 2007 10:28 pm
Get the oil level checked , has it ever been changed ?
Unit 20
0151 3366888
mattysupra
Post by mattysupra » Mon Nov 26, 2007 11:25 pm
I have also noticed on mine that if i leave in 'D' and drive at about half throttle, that it feels like it is going to change gear but then changing its mind. feels a bit like a miss fire but it is not that as i can hear the engine etc. It also seems to have a bit of a slip on it too. It dont do this if using the paddles etc.
Also is there a way to make it pull off in second or third gear maybe instead of it always changing into first. Basicaly make it lock in the gear that you want and not kick down?
slippery
Post by slippery » Tue Nov 27, 2007 12:02 am
Hi
Gearbox oil, filter & gasket changed 6 months ago due to leak.
Can Audi only check the level?
Cheers Tom
SteveH
Post by SteveH » Tue Nov 27, 2007 10:20 pm
@mattysupra, am not aware of being able to over-ride stock programme... anything programmed in should be able to be programmed out, so VAGCOM cable & programming?
Present:...
Past:
Users browsing this forum: Bing [Bot] and 124 guests
