Engine Management Warning
Car is 4,000 miles on the clock, registered July 2007 and now locked up at dealer having had an engine warning light come (amber EPC light on dash but it started flashing) on last night and had to be "rescued" by Audi Assist. Waiting for Technician at Dealership to call back with an update, following diagnostic test. Car run on Shell V-Power and no other running issues. Anyone else had a similar experience ?
tartan_rob
Thanks for for the responses guys, much appreciated. Audi Assist guy thought one cylinder was down, dealer staff suspected coil-pack issues. I'm still awaiting a reponse from the Technician so I'll update you later. Seems that it's a fairly common problem and nothing too much to worry about. Shame it happened on a Sunday afternoon returing from holiday with a boot full of luggage !! Just my luck !!
this happened to me twice now and they feed me a load of crap i told them to sort it or have the car back , in the end a audi tuner told them to change the maf sensor and since then been ok , i must admit though it is not the car i expected , dont feel like 400 bhp but will loose to much at moment to replace so will have to put upDiggler wrote:Thanks for for the responses guys, much appreciated. Audi Assist guy thought one cylinder was down, dealer staff suspected coil-pack issues. I'm still awaiting a reponse from the Technician so I'll update you later. Seems that it's a fairly common problem and nothing too much to worry about. Shame it happened on a Sunday afternoon returing from holiday with a boot full of luggage !! Just my luck !!
Exactly the same as I was told. No fault codes found. Keep taking it back, I had to - four times!. As mentioned previously, mine needed a new inlet manifold, half days work on warranty. From something that used to happen nearly every time I drove it, no EPC lamp in six months now.
Current
'10 Nissan GT-R Black Edition, Kuro Black.
'59 Scirocco 2.0 TFSI
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'07 RS4, Phantom black saloon
'57 Clio 197
'04 Aprilia RSVR Factory. Black.
E46 M3 SMG, Alpine white
E46 320i coupe
E36 328is coupe
VW golf VR6
Screw you guys!' - Eric Cartman
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
tartan_rob
Hey - ho my emissions light came on AGAIN. I gave Audi some stick and pointed towards VAG-com. Once they saw this they backed off a little and told me the fault had been recorded 12 times by my ECU. They are now going to get the car in for 4 days or so to investigate it in mid Jan.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
Rob, I've just emailed my dealership to get the precise fault that was found on mine (which needed the manifold change to fix). I'll post it here if I get a response so your tech can have a look. At least you'll be able to count it out if yours is ok.Tartan_Rob wrote:Hey - ho my emissions light came on AGAIN. I gave Audi some stick and pointed towards VAG-com. Once they saw this they backed off a little and told me the fault had been recorded 12 times by my ECU. They are now going to get the car in for 4 days or so to investigate it in mid Jan.
Keep with it chief, I understand why you're fed up. I was well disappointed when mine was going wrong, but its not missed a beat since.
Current
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
Tartan_Rob. Got this back from the service manager at my dealership today:
The fault which was stored for your car was:
08213 P2015 008
Intake manifold flap position sender,
implausible signal
Sporadic
At least they'll be able to rule it out if it doesn't fix it. Mine took four visits to fix, difficult to find being so intermittent I guess.
Hope this helps.
08213 P2015 008
implausible signal
Sporadic
Hope this helps.
Current
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
- reevesroadster
Why arent they investigating till mid Jan - and why 4 days?? Hope you are getting a decent courtesy car!!
I had the same problem - simialr story to other posts that the problem wasnt found on first few visits. Armed with this thread you should have your problem sorted in no time, assuming its the same issue.
Everyone is unique, just like you and me.
I was told originally that this would take 3 days to do (and was asked to provide insurance docs etc for courtesy car). This was reduced to 1/2 day after i asked why three days. MAKE SURE THEY TOP YOUR FUEL UP TO WHERE IT WAS WHEN YOU DROPPED IT OFF (or take it in empty!!)
Current
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 164 guests
