Hi All,
my rear diff seals need replacing and i have tried searching the net for a how to or any advice. i cant seem to find anything, so i was hoping that someone would be able to give me some advice or point me to a useful guide somewhere.... i wanted to get MRC to do it for me but they are fully booked for the next few weeks and i wanted it done before...
thanks!!
Kyle
Rear Diff Seals
RE: Rear Diff Seals
I asked a similar question a while ago... I'm still none the wiser. I can't think it's that hard a job though.
Mark
RE: Rear Diff Seals
Undo yr flanges, drop the driveshafts, undo the centre bolt now revealed in the centre of yr flanges, remove flange, replace oil seal, put it back together....
tip* - make sure yr oil filler plug comes loose whilst flange is out on o/s...its easier to get too then for topping up later... POP
happy dayz .... party ....
RE: Rear Diff Seals
Had mine done today at a great VW Audi specialist called Nottingham Auto-technik! I can recommend!!
The leak looks worse than it is.... the oil level was still OK, but I dont like oil on the driveway..
'91 230E Merc. Made when Germany knew how!
'99 S4 Saloon Silver. Made after it had forgotten!
RE: Rear Diff Seals
I should have said the leak looked worse than it was.... No leaks now! plus changed the LHS EGT and now have full boost again WAHEY.... I must say I dont mind working on cars, but both those jobs would have been a reet pain to do on the driveway... in the cold using my wooden ramps.
LHS (near side) EGT is just a to55 job to do. RHS looks a piece of cake!
RE: Rear Diff Seals
http://www.vagcat.com/p/B157/525200.png
I should do the same job, but how i have understood it - is that you need to measure the correct location of the oil seal (part 18 ), cause there is nothing to prevent it going too deep inside when putting in the new one.
