VAGCOM fault.
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
nickelvery
VAGCOM fault.
Post by nickelvery » Tue Nov 13, 2007 6:23 pm
I ran VAGCOM today and found this fault. I also noticed that when slamming on the brakes there is a noise from the front left wheel. Like an ABS sound.
Address 03: ABS Brakes
Controller: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 00899
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
Any ideas, thanks in advance.
Nick
Edgy
RE: VAGCOM fault.
Post by Edgy » Tue Nov 13, 2007 9:27 pm
Could the ABS sensor be faulty - I had both front ones go on mine. However I was getting a judder upon slow stopping just before the car actually stopped - not really a sound like you say.
Edgy
Avus RS4 - 710N's - MRC Custom Remap
imolas4uk
RE: VAGCOM fault.
Post by imolas4uk » Thu Nov 15, 2007 12:16 am
the load signal is generated by the air mass meter,check your maf readings
1999 S4 bi turbo imola yellow,grey pearl wheels,now with KO4's.
2001 A6 avant 2.5 tdi,the work horse
nickelvery
Re: RE: VAGCOM fault.
Post by nickelvery » Thu Nov 15, 2007 10:18 am
imolas4uk wrote:the load signal is generated by the air mass meter,check your maf readings
What even though it's to do with the brakes?
I'll have a look today.
Nick
jimbogrey
Post by jimbogrey » Fri Nov 16, 2007 4:43 pm
surely the error message refers to the ECU on the ABS unit!!
shineydave
Post by shineydave » Fri Nov 16, 2007 6:27 pm
the ESP reduces power by taking into account the load signal from the MAF so if you have a faulty MAF it can show a ESP/ABS fault since the ABS and ESP use the same sensors
Sebastian
Post by Sebastian » Mon Nov 19, 2007 1:55 pm
Updated our WIKI to cover this code...
http://wiki.ross-tech.com/index.php/18265/P1857/006231
...and as suggsted before thise code usually comes in combination with codes in the Engine Control Unit (ECU). Your code is intermittent which means the related Engine Control Unit (ECU) code may already be cleared, but you should check for fault codes there too. A common cause for this would be a bad MAF.
Sebastian @ Ross-Tech.com
nickelvery
Post by nickelvery » Tue Nov 20, 2007 12:05 am
Thanks for all your replies, which brings me on to how much does a MAF cost?
Thanks in advance
Nick
MarkB
Post by MarkB » Tue Nov 20, 2007 9:27 am
About £75 for an exchange unit from Audi
Mark
nickelvery
Post by nickelvery » Tue Nov 20, 2007 11:31 pm
MarkB wrote:About £75 for an exchange unit from Audi
Thank you.
Sebastian
Post by Sebastian » Wed Nov 21, 2007 8:03 am
...but before replacing you may want to actually test it. ;)
Return to “DTC / VCDS”
