How big a BORE can the RS4 2.7T block take???
2.7 V6 30v biturbo - 380 bhp
surfpilot
Post by surfpilot » Tue Nov 13, 2007 1:26 pm
I heard it can be bored out to 83.5mm is this true???
I am rebuilding my RS4 2.7T block and have been offered by my parts source the following pistons:
a) JE Forged 81.5mm with 8.5:1 compression
b) JE Forged 82.5mm with 9.0:1 compression
Which PISTONs should I choose???
FYI, I have no imediate plan of replacing my K04-25/26 turbos.
I really would appreciate your comments guys!!! Thanks again guys!
Manny
'01 RS4
Philippines
musty1
RE: How big a BORE can the RS4 2.7T block take???
Post by musty1 » Tue Nov 13, 2007 3:14 pm
wossner do a set of pistons for £750 with a 8.0.1 compresssion they are good to
1.9TDI A6 are sh*t wrong forum
surfpilot
Post by surfpilot » Tue Nov 13, 2007 3:18 pm
whats the advantage of bringing down my compression if will NOT be replacing my K04-25/26??
dummi
Post by dummi » Tue Nov 13, 2007 10:01 pm
you would drop cr if you are packing more air in than standard, i doubt you are with the k04's
simple1
Post by simple1 » Tue Nov 13, 2007 11:06 pm
The only reason for dropping the compression ratio would be to increase boost pressure, which you will not get from KO4's so seems little point. If you were going for RS6/hybrid turbos then a drop in compression would be an advantage. Bearing in mind that I dont build engines for a living, I could very well be corrected here.... :lol:
Blue_Thunder
Post by Blue_Thunder » Wed Nov 14, 2007 10:35 am
I thought you could run more aggressive timing if you had a lower CR???
musty1
Re: RE: How big a BORE can the RS4 2.7T block take???
Post by musty1 » Wed Nov 14, 2007 12:42 pm
Blue_Thunder wrote:I thought you could run more aggressive timing if you had a lower CR???
and more boost.
surfpilot wrote:whats the advantage of bringing down my compression if will NOT be replacing my K04-25/26??
if you dont want to drop your compression why buy je pistons standard rs4 pistons are good enough I was just giving you another option.
also if your rebuilding the block why not do CR drop so if later your turbos fail you can buy rs4/rs6 hybrids or use rs6 turbos with no problems
surfpilot
RE: Re: RE: How big a BORE can the RS4 2.7T block take???
Post by surfpilot » Wed Nov 14, 2007 1:07 pm
standard RS4 pistons are more expensive than JE's from my supplier. :(
musty1
Post by musty1 » Wed Nov 14, 2007 1:21 pm
try o34 motorsport they do both
S2tuner
Trader (Expired)
Post by S2tuner » Wed Nov 14, 2007 4:27 pm
If standard bore is a requisite (i.e. no rebore needed) I wouldn't go for anything other than OEM pistons, no matter how much cheaper anything else is!!!!
surfpilot
Post by surfpilot » Fri Nov 16, 2007 3:32 pm
i would also!...but my bore #6 has some scratches after one of my exhaust valves broke. :( would a 82.5mm piston with a 9.0:1 compression ratio be advisabble in my situation?? thanks!
dummi
Post by dummi » Fri Nov 16, 2007 4:06 pm
standard CR is 9.3:1 iirc , if thats the case yes
S2tuner
Trader (Expired)
Post by S2tuner » Fri Nov 16, 2007 4:15 pm
Standard CR on an RS4 is 9.0:1.
carpy
Post by carpy » Fri Nov 16, 2007 11:09 pm
What is that anyway. 9 degrees, 0 minutes, 1 second.........
hardhitter
Post by hardhitter » Fri Nov 30, 2007 4:26 pm
The relation of total cylinder volume divided by clearance volume, just a ratio
