4 shocks in as many months
el_ringo
Post by el_ringo » Thu Sep 20, 2007 9:02 pm
Hi,
Sorry to drag up the old DRC debate but I have managed 4 new shocks in nearly as many months. In May I had both rear shocks including both the valves done. The next month the OSR shock leaked and was replaced on its own and then today the OSR has been replaced for the third time.
What is the current guide about what should be replaced? Should the valves be replaced with a shock? I was expecting a few visits a year with the DRC but it is getting silly.
R
GardinerG
RE: 4 shocks in as many months
Post by GardinerG » Thu Sep 20, 2007 9:15 pm
The valves only need to be replaced if the pressure is too low due to leaks IIRC.
I'm having it ripped out and the Bilstein PSS9 put in.
nrf
Post by nrf » Fri Sep 21, 2007 9:36 am
Mine is currently having all four shocks and both valves done. Dealer actually said to me "only two shocks are leaking but as they are both at the front that means we need to do all four and both valves". Two of the shocks were done in December last year (previous owner) but not sure the valve was done. The best bit is that the warranty is paying for it - that and I now get to discover how its meant to handle!
Dave500
Re: RE: 4 shocks in as many months
Post by Dave500 » Fri Sep 21, 2007 9:57 am
nrf wrote:Two of the shocks were done in December last year (previous owner) but not sure the valve was done.
Hi mate you still got the car then :thumb: its it now behaving..... As far as I know they didn't replace the valve.
TVR Chimaera 500
Audi RS6 (now gone)
TVR Cerbera 4.5
Porsche C4S
nrf
RE: Re: RE: 4 shocks in as many months
Post by nrf » Fri Sep 21, 2007 10:06 am
Yup - still have it! Engine management light issue fixed when they found a sticky valve in the emissions control system which was confusing the system. I had loan cars for my first 3 weeks of owning the RS! Have had 3000 touble free miles now. Even starts when its warm! God knows how much they spent on it tracking down that valve! DRC now finally being addressed too. Thanks for your help!!
Dave500
Post by Dave500 » Fri Sep 21, 2007 10:15 am
Its good to hear everything has now been sorted out. The car must be like new :D
TVR Chimaera 500
Audi RS6 (now gone)
TVR Cerbera 4.5
Porsche C4S
el_ringo
Post by el_ringo » Fri Sep 21, 2007 6:12 pm
I have to admit, the car has been the best it has been with this new shock. I wonder how long it will last?
Daytona Grey (C5) RS6 saloon, but just a little better...
**** SOLD!!! :( ****
KW V3 suspension
390mm C6 Brakes
Hotchkis ARBs
Viper Tuning (537bhp 604lbft)
Unit 20 TCU remap
Milltek non-res exhaust and downpipes
100 cell sport cats
Aero wipers
Winter wheels
Wagner intercoolers
LED interior lights
Tesla Model S 85D
All the options with the exception of stupid air suspension
Tesla Model X 60D
Silly doors and all!
HyOctane
Post by HyOctane » Fri Sep 21, 2007 7:59 pm
Anytime you replace any shocks, you must also replace the corresponding central valves as well as properly refilling the system (shocks and lines) from a negative pressure (vacuum). The operating pressure should be between 12-14 bar. It can be checked with a special gauge by your tech to see if it is properly pressurized. Anything under 12 bar means improper repair/function and needs to be redone. the good news is that Audi will soon be offering a special toolkit that will allow the central valves to be recharged rather than having to purchase new ones every time. This should speed up repairs and reduce costs significantly.
Cheers!
Jani
Post by Jani » Mon Oct 01, 2007 11:37 am
My suspension is now giving a squeeking sound when driving, is this normal with DRC-failure? Even standing still, if you push the rear to make suspension move, it makes a squeeking sound.
I would appreciate a print or a link to official guidelines with DRC. What does the factory maintenance manual say, what is the correct procedure to fix the suspension?
rs6nick
Post by rs6nick » Fri Nov 09, 2007 9:30 pm
I spoke to the Audi technician in Aberdeen who advised when replacing DRC parts to replace the alluminium washers belween the valve-hose-shockers with brass washers. Apparently failure often occures due to corrosion at these connections.
