The Hama 4GB SD Card found (http://www.valuemedia.co.uk/4Gb_sd_card.htm) works fine with the RNS-E after it's been formatted to FAT32 and 4096 byte blocks (arrived with 32K blocks). Costs about £30 after delivery (2 days for my order).
Hopefully saves someone a bit of time, as other vendors seem to have supply problems of the non-HC 4GB SD Cards judging by the two cancelled orders I had.
4GB SD Card for RNS-E - Valuemedia.co.uk
07 B7 RS4 Avant - Misano Red
11 E71 X6 40d - Alpine White
- Scoobysnack
- 1st Gear
RE: 4GB SD Card for RNS-E - Valuemedia.co.uk
is this an HC SD card, or a normal one ? Hopefully normal?
J
J
Re: RE: 4GB SD Card for RNS-E - Valuemedia.co.uk
A normal one, plain old SD Card (Rated at I think 133x)Scoobysnack wrote:is this an HC SD card, or a normal one ? Hopefully normal?
J
oilman4345
- 1st Gear
Re: 4GB SD Card for RNS-E - Valuemedia.co.uk
I have a 4gb card which I have given up on as it did not play in the car. (now use 2gb instead). How do you format the 4gb as you mention in your post, as I will try and re-format!dubbers wrote:The Hama 4GB SD Card found (http://www.valuemedia.co.uk/4Gb_sd_card.htm) works fine with the RNS-E after it's been formatted to FAT32 and 4096 byte blocks (arrived with 32K blocks). Costs about £30 after delivery (2 days for my order).
RE: Re: 4GB SD Card for RNS-E - Valuemedia.co.uk
Why not just buy more 2Gb cards. You can get 3 x 2Gb for the price of a 4Gb.
http://www.mymemory.co.uk/memory/MyMemo ... e/Digital)
Cheers,
Daz
Audi RS4 Cabriolet with added Milltek - Gone
Daz
- PetrolDave
SDHC cards won't work in the RNS-E, only "normal" SD ones.Scoobysnack wrote:is this an HC SD card, or a normal one ? Hopefully normal?
J
Just right click the SD card driver letter - Select format, choose options as shown.oilman4345 wrote:I have a 4gb card which I have given up on as it did not play in the car. (now use 2gb instead). How do you format the 4gb as you mention in your post, as I will try and re-format!dubbers wrote:The Hama 4GB SD Card found (http://www.valuemedia.co.uk/4Gb_sd_card.htm) works fine with the RNS-E after it's been formatted to FAT32 and 4096 byte blocks (arrived with 32K blocks). Costs about £30 after delivery (2 days for my order).
It does take the RNS-E a while to load a 4GB card. In my case 600 songs takes about 2 minutes.
np Bigh - hope its useful
Users browsing this forum: No registered users and 240 guests
