MPG Display Wrong
ajsl
RE: Re: RE: MPG Display Wrong
Post by ajsl » Thu Nov 01, 2007 5:38 pm
The differences aren't nearly as large as you guys are calculating :).
The key thing here isn't the rim diameter (17" vs 18") is the total rolling radius including the tyre. For instance you're probably running lower profile 18" tyres.
i.e. on my car I have 18" B6 S4 wheels and tyres to replace my standard 17" ones.
The standard S4 17" wheels come with 225/45 R17 tyres, where as the 18" B6 wheels have 235/40 R18 tyres. So even though they have a larger inside diameter they have a lower profile.
Using somewhere like
http://www.tiresizecalculator.info/
Gives:
Original tire
Sidewall: 3.99 in
Radius: 12.49 in
Diameter: 24.97 in
Circumf: 78.45 in
Revs/mile: 807.61
New Tire
Sidewall: 3.70 in
Radius: 12.70 in
Diameter: 25.40 in
Circumf: 79.80 in
Revs/mile: 793.97
Speedometer reading with new tire is 1.72% too slow.
When your speedometer is reading 60mph you are actually traveling 61.01mph.
So the difference isn't as great as the rim size change would indicate :).
derdle
Post by derdle » Thu Nov 01, 2007 8:24 pm
We all know your such an honest guy Clive!
RS4 in the only colour to have - Misano Red | MRC Remap | RS6+ brakes | H&R and Custom Performance Parts suspension |
Huge Grin :biggrin3: If you dont "do it now" you never will.
CliveH
Post by CliveH » Thu Nov 01, 2007 10:18 pm
Alex - absolutely right - I'd assumed Paul had taken account of that, but of course he doesn't know the size of the tyres on my 18s :roll:
Paul - even so, point well made - you could make an honest car salesman of me yet... :lol:
Clive
derdle
Post by derdle » Fri Nov 02, 2007 10:36 am
I'd forgottten all about the tyres. Doh! Just goes to show how stressed out I was yesterday and I didn't even realise it.
Sorry guys.
I'll get my coat an go hibernate for the rest of the winter.
Paulzzzzzzzz
viperbl
Post by viperbl » Fri Nov 02, 2007 10:39 am
How about with full tread and low tread! this must make a difference as well! :o
RS4 B5 Saloon8) with 750+ bhp :D
DavidT
Post by DavidT » Fri Nov 02, 2007 10:48 am
You will need to change the setting for the injectors to get your mpg closer. Its in the dash I think. Bigger injectors are using more fuel in the same duty cycle compared to the original small ones so the mpg reads too high. Mihnea did mine and got it pretty close.
viperbl
Re: RE: Re: RE: MPG Display Wrong
Post by viperbl » Fri Nov 02, 2007 10:51 am
DavidT wrote:You will need to change the setting for the injectors to get your mpg closer. Its in the dash I think. Bigger injectors are using more fuel in the same duty cycle compared to the original small ones so the mpg reads too high. Mihnea did mine and got it pretty close.
As in an adaptive channel that we can do in vag com? or is it a Mihnea only change???
DavidT
RE: Re: RE: Re: RE: MPG Display Wrong
Post by DavidT » Fri Nov 02, 2007 10:52 am
Dunno, ask him.
viperbl
Post by viperbl » Fri Nov 02, 2007 10:53 am
Will do:)
CliveH
Post by CliveH » Fri Nov 02, 2007 11:03 am
Is it not simply this...? :shock: http://www.rs246.com/index.php?name=PNp ... ic&t=47768
Clive
viperbl
Post by viperbl » Fri Nov 02, 2007 11:27 am
CliveH wrote:Is it not simply this...? :shock: http://www.rs246.com/index.php?name=PNp ... ic&t=47768
We've been there and done that on the first page of this thread :lol: :wink:
Problem was mine was so far out because of the new injectors that this fix was not enough, ie, I was out by over 130%, and this only allowed 115% difference...
derdle
Post by derdle » Fri Nov 02, 2007 11:30 am
You could put some really small wheels (and tyres) on the car to compensate?
CliveH
Post by CliveH » Fri Nov 02, 2007 11:46 am
exactly, that's where this all started, but my understanding is that's how to do it, and you can then 'fine tune' after the first 115 (or 85 in my case) adjustment...? :?
Mihnea/Doug - is there another way?
Clive
DavidT
Post by DavidT » Fri Nov 02, 2007 11:54 am
No Clive, you are talking about fine tuning with that when what you really need is a major setting change.
CliveH
Re: RE: Re: RE: Re: RE: MPG Display Wrong
Post by CliveH » Fri Nov 02, 2007 12:08 pm
DavidT wrote:No Clive, you are talking about fine tuning with that when what you really need is a major setting change.
aha, then I have misunderstood - where does one find such major setting change please?
Clive
Users browsing this forum: Google [Bot] and 51 guests
