EGT Error
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
am8631
EGT Error
Post by am8631 » Sun Oct 21, 2007 5:48 pm
here is what i have:
1 Fault Found:
17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
P1453 - 35-00 - -
Readiness: 0000 0000
VAG-COM Version: Release 704.1
Data version: 20071016
should i be overly concerned? The reason i say this is because the car is running really well, peak MAF of 260 and no loss of boost.
how quickly should i have this sensor changed?
ta
Andy
yorkie
RE: EGT Error
Post by yorkie » Mon Oct 22, 2007 5:25 pm
What car is it?
Whenever I get this fault code the car goes into limp mode so I'm surprised yours hasn't.
I assume you have checked actual vs spec boost to confirm this?
am8631
RE: EGT Error
Post by am8631 » Tue Oct 23, 2007 1:04 pm
sorry, its an S4 (b5). I have logged the actual/spec boost and its all fine. Are there any other blocks that i can measure to help shed some light on this? The car is pulling like a train at the mo but i would like to know if something is about to let go.
ta
yorkie
RE: EGT Error
Post by yorkie » Tue Oct 23, 2007 6:12 pm
Maf of 260 is very high for a std car so I assume not std?
am8631
RE: EGT Error
Post by am8631 » Tue Oct 23, 2007 8:15 pm
nope - a little MRC tweaking - custom remap and a custom backbox.
yorkie
RE: EGT Error
Post by yorkie » Tue Oct 23, 2007 8:44 pm
I would just change the egt then.
G235 is the driver's side one which is pretty easy to change.
am8631
RE: EGT Error
Post by am8631 » Tue Oct 23, 2007 11:10 pm
cool - i'll get one ordered.
Return to “DTC / VCDS”
