rs2 discs
RE: rs2 discs
they are available from audi,but very expensive.i would suggest the ebay.de for discs.I bought my rear discs from there a year ago.pretty good!
RE: rs2 discs
Im actually after them to put on a porsche so need to know if they will fit !!!
RE: rs2 discs
in any case i think buying them from porsche is cheaper.in audi here in greece it costs around 500euro each disc
RE: rs2 discs
Part numbers I found in another forum.
Standard Brake Kit
Porsche Part List for Audi RS2
Front Discs 928 351 043 60
928 351 044 60
Front Pads 993 351 939 01
Front sensors 928 612 365 01
Damp Pads Front 964 351 096 01
964 351 096 00
Upper Caliper Plates 993 351 959 01
Front Caliper Bolts 900 067 154 02
Front discs were 928 parts by the look of it. Worth finding someone in the Porsche Club GB to source parts as they get a 20% discount which makes Audis prices even more expensive.
Standard Brake Kit
928 351 044 60
964 351 096 00
RE: rs2 discs
Thanks for the replys, Im after some rear discs,the rs2 rear discs do look like the 944 turbo/968 ones but i just need to make sure before buying them !!
scillyisles
BTDT - rs2 discs were sourced from Porsche but on the rear in particular Audi used AFAIK a different hat size meaning it will not fit on a Porsche.
I like others have done tried to get new discs from Porsche his year - got part number from s2forum.com - despite many attempts and conversations between my Audi dealer and Porschce dealer they could not get them to fit. Ended up buying Audi ones from Audi.
see http://www.rs246.com/index.php?name=PNp ... d85f2df5c0this post
Audi RS2 - the original
The Part number im told for the RS2 rear disc is 8A0 615 601 D,the disc looks the same as the 944 turbo apart from the porsche ones are not drilled which is why i wanted the audi ones. According to the link there is 25mm difference in hat size which i dont think would fit my porsche as im running 9.5" rear wheels !!! The 951 part number seems correct for my car but seems funny as the 944 turbo came with non drilled rear discs.
