Oh bugger - my new wheels don't fit !
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
saf
Post by saf » Mon Oct 15, 2007 11:04 am
Universal spacers are not good at all fr use on these cars,. They can be very weak.
You need some propper H&R or Eibach hubcentric spacers.
I have the same wheels as Gavster, and use 10mm spacers as I need to clear massive brakes.
They spacers are expensive money but well worth it. Its the only way you can go if you want to put those wheels on.
They usually go for around £140 for a good set. I paid £160 for a set of H&R ones.
If you want some second hand 5mm eibach pro ones which are exactly the same as the H & R ones quality wise, PM me and you can have them far cheaper than RRP as I got some with my set of B6 wheels.
Phone around for some prices then give me a call if you need them.
Either way I hope you get your wheels sorted.
AdamS4
Post by AdamS4 » Mon Oct 15, 2007 11:26 am
Do the good one with hubcentric come with longer bolts ??
reserves
Post by reserves » Mon Oct 15, 2007 12:07 pm
Am I the only one who doesn't need *ANY* spacers???
buzzard
Post by buzzard » Mon Oct 15, 2007 5:05 pm
so we have no conclusion on this because we have different callipers on different ages.
i hope to fit some of these wheels soon and this is a really helpful thread.
but a conclusion would be nice.
S4 B5 long gone
S4 B8 Stage 2
tdiquattro
Post by tdiquattro » Mon Oct 15, 2007 11:20 pm
There still seems to be a number of different views out there, I have genuine B6 alloys, and had to install 5mm spacers at the rear to clear the uprights, and 3mm at the front to clear the calipers. 235 tyres. but ohters have fitted them with no spacers, I cant see how as if you put a couple of bolts in my rears with no spacers they do not turn!
So I don't know, but the thin spacers do line them up very nicely with the arches, just inside but very neat.
I also had rubbing at the front when lowered, but again ohters have said no rubbing, so to e honest I'm confused!
I know this doesnt help!, sorry.
Nigel.
Nige'
2000 silver S4 Saloon
AdamS4
Post by AdamS4 » Tue Oct 16, 2007 10:46 am
Anyone happen to know what type of seat the std bolts are ? I think there tapered :?
http://www.rimstyle.com/pages/products/ ... =DR325112B
MarkB
Post by MarkB » Tue Oct 16, 2007 10:58 am
OEM bolts are radius seat. It's the aftermarket bolts that are tapered
Mark
MarkB
Post by MarkB » Tue Oct 16, 2007 10:59 am
Radius is sometimes also called domed
Mark
AdamS4
Post by AdamS4 » Tue Oct 16, 2007 11:09 am
I'll check what my new wheels take and go from there
Bosun20
Post by Bosun20 » Wed Oct 17, 2007 12:29 pm
I have had B6 S4 alloys fitted to my car(B5 S4 Avant) now for about a year.Kept the 235 size tyres on them.Used 3mm spacers allround,the rear just caught the suspension without,and ground some off the front calipers to get more of an angle were the wheel did touch.Plenty of clearance with new pads fitted.I`m not really a fan of spacers but i have never had a problem and still use the standard bolts.
reserves
Post by reserves » Fri Oct 19, 2007 5:01 pm
Ok, take it back, I do need spacers after all, the rear wheels rub on the suspension arm.
Does anyone know if I fit RS4 Suspension this will sort it? What width and offset are standard B5 RS4 alloys?
MarkB
Post by MarkB » Fri Oct 19, 2007 6:15 pm
The suspension on the RS4 is much the same. Standard they run 8.5" x 18" @ 20MM offset
Mark
