K03 goes woo-woo on youtube
RE: K03 goes woo-woo on youtube
sounds like air wolf
Arrggh that sounds bad.
You can hear the air leak, no wonder they failed
- tdiquattro
that's exactly what my drivers side k03 sounded like when it went, hot side turbine blade sheared off!, no boost, but no smoke.
Nige'
2000 silver S4 Saloon
- GrimReaper
Re: RE: K03 goes woo-woo on youtube
Thats exactly what happened to my offside tubby as welltdiquattro wrote:that's exactly what my drivers side k03 sounded like when it went, hot side turbine blade sheared off!, no boost, but no smoke.
KO4's Full Bilstein suspension, MRC custom remap Dual milltek, de pre-catted & custom Decats Forge DV's H&R ARB's, 18" RS4 Reps
Cayenne calipers B5 RS4 discs PICS: http://s8.photobucket.com/albums/a4/sjy666/Audi%20pics/
MarkHanman
OK. resurrecting an old thread...
Turbo failure, left hand side, from inside the car, when boost is building, it sounds remarkably like the sound in the preceding clip.
In addition, there is a rattle at idle.
Is it fair to 'suspect' then that the manifold has separated internally?
What is the exact cause of the high pitched whine? Is it turbo damage? Or boost leak?
If the former, I've now read a few bits to understand what's going on.
If the latter, from where would this be coming (common cause on B5?)
If the manifolds need replacing, would someone post the part numbers to ensure I get the right ones? What price?
Cheers,
And in anticipation...
bugger
Cheers,
bugger
