Screenwash
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
stark
Screenwash
Post by stark » Sun Oct 14, 2007 12:07 pm
My car leaked about 5 litres worth of screenwash last night after washing my windscreen... Had a similar issue on my old A4 but that was just a case of reattaching one of the hoses which had become lose.. Access in the S4 is very limited, and im finding it difficult to see where exactly the problem lies... Any ideas?
Blue_Thunder
RE: Screenwash
Post by Blue_Thunder » Sun Oct 14, 2007 12:33 pm
Check the pump. It's a common fault on these. When mine had gone, it literally cracked right the way up the plastic and was very obvious.
Add some more water to the car so you can see where it's coming out from.
shineydave
RE: Screenwash
Post by shineydave » Sun Oct 14, 2007 1:56 pm
you'll have to remove the N/S wheelarch liner to see properly, 5 minute job
Dave
MarkB
RE: Screenwash
Post by MarkB » Sun Oct 14, 2007 5:56 pm
Just found a puddle under mine and plenty of drips underneath so may be suffering the same...
Mark
mad-for-tar
RE: Screenwash
Post by mad-for-tar » Sun Oct 14, 2007 6:38 pm
Mine leaked at the T-junction behind the front bumper LH grille, O-ring was squashed, took me ages to find the leak, new o-ring, some patience and all was sorted.
There are 2 tools you need in life: WD-40 and Duct Tape.
If it moves and it should'nt, use the Duct Tape
If it doesn't move and it should, use the WD-40
mattsimis
Re: RE: Screenwash
Post by mattsimis » Mon Oct 15, 2007 12:42 am
MarkB wrote:Just found a puddle under mine and plenty of drips underneath so may be suffering the same...
The AC drips condensation around the area too. I thought I had a leak after replacing the headlight washer pump when I just got the car. It was of course split up the middle, such a poor designed part.
V10 5.0 Phaeton now and 2.7T Allroad
docwyte
RE: Re: RE: Screenwash
Post by docwyte » Mon Oct 15, 2007 2:04 am
If you've been running the AC and stop the car, it's the drain from the AC. If it's wiper fluid, you've either cracked the tank, or had the pump O-ring drop into the tank.
Replacing the tank is easy, but you do have to remove the drivers side wheel and inner fender liner.
jeffw
Post by jeffw » Mon Oct 15, 2007 6:19 am
Or passenger side wheelarch liner and wheel if your not American....
MarkB
Re: RE: Screenwash
Post by MarkB » Mon Oct 15, 2007 8:48 am
Looked like I had water dripping off the anti roll bar. The AC puts out water further back doesn't it?
I'll be keeping an eye on mine now...
Mark
stark
Post by stark » Tue Oct 16, 2007 11:45 pm
Not had time to do any investigation so far this week, washer light has been on since saturday - its beginning to get annoying now! Will see what i can do over the weekend, does the wheelarch liner simply slip off? Im a noob when it comes to car maintenance, guess ill have to learn the hard way... Cheers for the help
Users browsing this forum: No registered users and 58 guests
