My aircon doesn't work at the moment. The system is gassed and the Aircon pump is working if you apply 12v to the supply for it. Fuse is OK. Ambient temp in the DIS shows what you would expect as far as external temp is concerned.
Question is...
What else should I check (other sensors and/or relay ?) and what other actions can I take to rectify this ?
Air con electrics (B5 S4)
- shineydave
RE: Air con electrics (B5 S4)
have you tried going through the built in diagnostic mode?
Dave
there is a pressure sensor in the drivers side of the of the condenser , if this shown it's low on pressure it wont allow the pump to work .
Unit 20
0151 3366888
0151 3366888
- shineydave
Here's the link to the codes and how to access them, was on the house pc earlier and didn't have the link in my favourites
http://www.tyresmoke.net/ubbthreads/sho ... &fpart=all
Dave
Users browsing this forum: No registered users and 149 guests
