Can the Press Clutch to Start be Overridden?
t_urbo
Re: RE: Re: RE: Re: RE: Re: RE: Can the Press Clutch to Star
Post by t_urbo » Mon Oct 08, 2007 3:29 pm
PetrolDave wrote:If you checkout the wiring diagrams (see the Bentley manuals) you'll see that no amount of coding with VAG-COM will change the fact that the clutch switch is wired in series with the starter button!
Doh!
So the next question is;-
Is the clutch switch only part of the circuit (as is the start button) pre start up?
If not is there anything else the switch operates?
MarkB
RE: Re: RE: Re: RE: Re: RE: Re: RE: Can the Press Clutch to
Post by MarkB » Mon Oct 08, 2007 3:30 pm
I would think it's linked into the cruise control. Knocks off cruise if you press the clutch...
Mark
SimonFV8
RE: Re: RE: Re: RE: Re: RE: Can the Press Clutch to Start be
Post by SimonFV8 » Mon Oct 08, 2007 3:58 pm
If all it is is a micro switch operated by the clutch peddle then it should be easy to strap it out, if it is easy to get to that is!!
I dont really see the point in the started button at all, on my old Touareg I had keyless entry and keyless start / stop which was really handy (especially for my wife when she had the keys in her handbag!!) Its the one thing i really miss on my RS4
RS4 Avant Avus Silver - With added APS
PetrolDave
Post by PetrolDave » Mon Oct 08, 2007 5:49 pm
SimonFV8 wrote:I dont really see the point in the started button at all
Let's face it, on the RS4 the starter button is just a gimmick.
Users browsing this forum: No registered users and 100 guests
