RS4 0-60 Times
t_urbo
Re: RE: Re: RE: RS4 0-60 Times
Post by t_urbo » Sat Oct 06, 2007 5:38 pm
rAudiguy wrote:How are you recording your times?
Through the Acceleration Module in VAG-COM.
RussianM3_dude
RE: Re: RE: Re: RE: RS4 0-60 Times
Post by RussianM3_dude » Sat Oct 06, 2007 5:43 pm
So what about 0-62 runs??? Or 0-100????
W8PMC
Post by W8PMC » Mon Oct 08, 2007 9:07 am
Nice one. I've found the same that dumping the clutch just over the 4K RPM mark seems to give the best results.
Can you expand slightly on your 6K dump (ooh err missus)??. You say the rev needle just rose but no traction, is this similar to my clutch problem as per Clutch Thread?? What happened over the following few seconds??
Paul
05 Blue DMS E60 M5 (Sold)
14 Grey LCi F10 M5 (Rejected)
t_urbo
Re: RE: Re: RE: Re: RE: RS4 0-60 Times
Post by t_urbo » Mon Oct 08, 2007 12:12 pm
W8PMC wrote:Nice one. I've found the same that dumping the clutch just over the 4K RPM mark seems to give the best results.
Yes this is exactly the same problem.
Being 4 wheel drive and having 400 odd bhp when you try to dump the clutch at too higher given output something has to give (tyres, clutch engine bog or Drive shafts :shock: ) so in the case of the RS4 its the clutch.
The clutch fails to engage properly and slips.
With mine the car failed to move, the revs rose, my eyes popped out then i opened the windows because of the sweet smell of clutch :D
When i was doing my 0-60, 0-100 sprints i was getting slip between gears just like you had when i never lifted off the gas enough.
W8PMC
RE: Re: RE: Re: RE: Re: RE: RS4 0-60 Times
Post by W8PMC » Mon Oct 08, 2007 1:17 pm
Ta very much, at least that puts my mind to rest that it's some kind of failsafe & not the clutch actually being deposited on the tarmac.
I have noticed that it's possible to sometimes change too quickly thus the revs never drop enough to engage the gear, or as you say & we both suffered, the revs are too high however it happens & the clutch stays engaged without dropping the gear correctly.
Paul
Users browsing this forum: Google Adsense [Bot] and 438 guests
