Can the Press Clutch to Start be Overridden?
Is it possible to Override this pain in the arse function?
RE: Can the Press Clutch to Start be Overridden?
wtf is it even required? agree totally, pain in the arse....
Current
'10 Nissan GT-R Black Edition, Kuro Black.
'59 Scirocco 2.0 TFSI
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'07 RS4, Phantom black saloon
'57 Clio 197
'04 Aprilia RSVR Factory. Black.
E46 M3 SMG, Alpine white
E46 320i coupe
E36 328is coupe
VW golf VR6
Screw you guys!' - Eric Cartman
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
It takes some loading off the starter motor and no doubt some Health and Safety Law plays or will play a part in it.
Re: RE: Can the Press Clutch to Start be Overridden?
Didn't know this. The old dear always starts her golf with the clutch in but couldn't explain why she does it. I guess she just knows better!!t_urbo wrote:It takes some loading off the starter motor and no doubt some Health and Safety Law plays or will play a part in it.
Current
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
- PetrolDave
RE: Re: RE: Can the Press Clutch to Start be Overridden?
There was a discussion about this a while back that got quite heated!
The root cause is the law suits against Audi in the US over 20 years ago when some dork tried to start his manual transmission car with it in gear and injured someone - the US courts blamed Audi instead of the incompetent driver. To avoid that happening they started making the starter motor only work when the clutch pedal is engaged on US model cars.
The benefit of reducing the load on the starter motor by dis-engaging the clutch and hence removing the load of the gearbox is especially noticeable on cold mornings when the gearbox oil is REALLY thick.
On the RS4 there's another good reason for pressing the clutch pedal ... try just tapping the "Start" button for a fraction of a second .....the starter motor will go through a complete start cycle until the engine starts taking several seconds, you DON'T need to hold the button down!
I can't imagine how many garage doors would be wrecked without it then!!
Current
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
Re: RE: Re: RE: Can the Press Clutch to Start be Overridden?
Cheers.PetrolDave wrote:There was a discussion about this a while back that got quite heated!
Soon you will have to fill out an on board Risk Assessment before the car will start, bloody joke. Still only got ourselves to blame.
Still would like to override it though if at all possible.
RE: Re: RE: Re: RE: Can the Press Clutch to Start be Overrid
Aaaaaaaaargh don't mention the R.A. words on here!!! This is where I come to get away from that sh*te!!!!!
Current
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
RS4v8 from now on I would like a method statement to tell us all your intensions of the day. you know the sort of thing. ( firstly i will switch my computer on using the on button. once the machine has booted up i will enter my password...... bla bla.... I bloody hate method staements RA and anything to do with H&S I have to deal with them all day long and it drive me mad!!Aaaaaaaaargh don't mention the R.A. words on here!!! This is where I come to get away from that sh*te!!!!!
Current car..... hmmmmm????
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
Agreed .... total BS......
Current
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
I totaly agree with the RA stuff but when I was taught to drive, it was banged into me to depress the clutch for the two reasons above - safety, just in case it's been left in gear and it does indeed take the load of the engine. Mind you, that was in the days when most of the cars I would have driven would have been 6V, dynamo and side valve so the battery needed every chance it could get.
Graham
Graham
I was just taught to waggle my knob. (the gearstick!). What did you think I meant?
Perverts the lot of you!
There is an adaptation channel in VAGCOM but not had ago yet.
http://wiki.ross-tech.com/index.php/Aud ... 8ED/8HE%29
Re: RE: Re: RE: Re: RE: Can the Press Clutch to Start be Ove
Are you talking about the coding options 1? its adaptation +16.byron13 wrote:There is an adaptation channel in VAGCOM but not had ago yet.
If so ive tried this but when you put the new code it keeps reverting back to its original code for some reason, so i was not sure if this is the right adaptaion code.
- PetrolDave
RE: Re: RE: Re: RE: Re: RE: Can the Press Clutch to Start be
If you checkout the wiring diagrams (see the Bentley manuals) you'll see that no amount of coding with VAG-COM will change the fact that the clutch switch is wired in series with the starter button!
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 1660 guests
