Don't cheapskate on brakepads!
CliveH
Post by CliveH » Sun Oct 07, 2007 11:51 am
When I first fitted the RS6/RS4 B7 front brake setup, I naturally shopped around for all the parts for such an expensive mod.
The calipers and discs I sourced are of course Audi/Brembo OEM.
When it came to the pads, I sourced some around £60 cheaper than the Audi (Pagid) ones. These were made by Lucas and 'looked' identical, so I thought they would be fine.
Firstly, they didn't quite fit, as the semi-circle which sits in the pad support bar needed rounding out with a file to get them to seat properly. But that wasn't a major issue at the time and was easily sorted.
However, although substantially better than the stock S4 setup, they have never felt 'right' and it was only when Doug (MRC) came to drive it recently that he said they felt poor, not how those brakes should preform, and he thought the pads needed changing. On inspection of the pads, there was plenty of wear left, so I decided it was time to fit the RS6 brake hoses which had been sitting in the garage for a while...
But whilst at MRC yesterday, I decided to swap the pads out for the RS4 B7 OEM ones, as the wheels were off. Some of the original pads were a bugger to get out (presumably due to the imperfect fit in the first place), some were a bit glazed and one had a quite a big 'crater', but not badly worn.
However, once bedded in and on the road, what a difference!
So that's my experience and little lesson learned - 'you get what you pay for'! (oh, and the fact that Doug is normally right first time :roll: )
Clive
dazzer
Post by dazzer » Sun Oct 07, 2007 11:55 am
Second that Clive. Don't jib on life saving kit, especially with your power.
S4TAN
Post by S4TAN » Sun Oct 07, 2007 5:56 pm
For some strange reason I feel compelled to make a glib comment about Clive being the Earl of Wakefield .... or something.
Deus ex machina
