Thanks for the EGT tip, which i will look into further ( as well as MAF, DV's, N75 etc !) This is my first turbo car and i am really starting to get very paranoid ...
Anyway, i managed to log some blocks with VAGCOM which show boost is way down ( not getting above 1400 mbar on full throttle). 115 log is as follows ( fields are - Time stamp, rpm, engine load %, specified boost mbar, actual boost mbar) :
Group B: '115
Engine Speed Engine Load Boost Pressure Boost Pressure
TIME (G28) (specified) (actual)
STAMP /min % mbar mbar
391.42 2880 13.5 990 1020
397.76 3200 105.3 1610 1330
398.66 3520 116.5 1650 1410
399.57 3840 118 1650 1410
400.48 4160 118 1650 1420
401.42 4480 120.3 1770 1410
402.39 4800 119.5 1880 1410
403.39 5120 121.1 2000 1410
404.42 5440 117.3 2090 1400
405.49 5760 118 2090 1390
406.58 6080 119.5 1670 1400
407.70 6360 115 1700 1380
408.83 6480 42.1 990 1350
Block 120 logs from the same session ( fields are - Time stamp, rpm, specified torque, actual torque, ASR status) :
Group C: '120
Engine Speed Torque specified Engine Torque Status
TIME (G28) by ASR (actual)
STAMP /min Nm Nm
391.72 2840 599.8 0 ASR OFF
398.06 3280 599.8 282.2 ASR OFF
398.96 3600 599.8 294 ASR OFF
399.87 3920 599.8 296.9 ASR OFF
400.79 4280 599.8 288.1 ASR OFF
401.74 4560 599.8 288.1 ASR OFF
402.72 4920 599.8 288.1 ASR OFF
403.73 5240 599.8 276.4 ASR OFF
404.77 5560 599.8 276.4 ASR OFF
405.85 5880 599.8 276.4 ASR OFF
406.95 6160 599.8 264.6 ASR OFF
408.08 6440 599.8 255.8 ASR OFF
409.20 5880 599.8 0 ASR OFF
( Dont know what ASR off is ?)
I see that i didn't really do the FATS log correctly as i started to do full throttle only at 3,000 rpm. But the boost shows values well down on specified ones.
The MAF reading at the same timegot upto 207 at 6,240rpm, so that seems to be ok ?
ANyway, i don't appear much further on and am trying to get the local garage to have a look at pressure testing the system ( not exactly sure what that is though but it is in a lot of other posts - a little knowledge is a dangerous thing), followed by MAF, EGT, DV and N75 replacements before resorting to the garage suggested new turbos - Yikes !
Anybody have any thoughts about the logs above that could give further light on the error codes in the OP and that might avoid having to go for new turbos and the engine out , please ?
cheers
soapy
