Much better
kaisersolsay
Post by kaisersolsay » Thu Sep 20, 2007 10:11 pm
Found them....they are located on the top of the boxes huh!!
Found the below clearer diagram on the Milltek website.
Gonna disconnected them tomorrow afterwork.....can't wait!
audijohn
Post by audijohn » Thu Sep 20, 2007 10:28 pm
Good find, should make a diference low down in torque and noise of course.
pippyrips
Post by pippyrips » Fri Sep 21, 2007 9:52 am
bit of a bugger to get to though!
s3marc
stuck?
Post by s3marc » Fri Sep 21, 2007 10:14 am
I am tempted to do this..... but bit concerned that they will get stuck open if not used - presumably when it needs and MOT or service, I should reconnect the pipe, otherwise it will be seen that it has been tampered with.
So when I reconnect them say for an MOT in 2 years time.... will the flaps be stuck open and fail the MOT on noise emissions?
Marc
audijohn
Re: stuck?
Post by audijohn » Fri Sep 21, 2007 12:35 pm
s3marc wrote:I am tempted to do this..... but bit concerned that they will get stuck open if not used - presumably when it needs and MOT or service, I should reconnect the pipe, otherwise it will be seen that it has been tampered with.
Marc
Highly unlikely, I think the bearings on the acuators will remain free, if not WD40, job done.
You will reconnect for serviceing anyway, so they will get some use now and then. :wink:
kaisersolsay
RE: Re: stuck?
Post by kaisersolsay » Fri Sep 21, 2007 7:43 pm
Hi guys,
I can confirm that my B6 S4 DOES NOT have the exhaust valves discussed.
I took the rear boxes off their rubber hangers and pulled them down, but there were no valves to be seen???!!
She only has 23k on the clock so I wouldnt have thought that the exhausts have been replaced with cheaper replacements??
Anyone got any thoughts?
I-want-an-RS
Re: RE: Re: stuck?
Post by I-want-an-RS » Sat Sep 22, 2007 10:09 am
kaisersolsay wrote:Hi guys,
Your car is tiptronic
kaisersolsay
RE: Re: RE: Re: stuck?
Post by kaisersolsay » Sat Sep 22, 2007 10:43 am
Hi,
Its a manual. Replacement exhausts? Really?? It has 23k on the clock?!! Are the exhausts likely to go that quickly? Getting worried the car has been clocked now. Bought her from Stockport Audi.....noticed on the vehicle reg docs that she has had 5 previous owners. Is there any way to check if shes been clocked??
Love_iTT
Post by Love_iTT » Sat Sep 22, 2007 10:46 am
Add me to the list of the open valves club :-)
Graham
Scoobysnack
Post by Scoobysnack » Sat Sep 22, 2007 11:22 am
De-Acutated for about 600miles....... So does anyone get any booming aboout 3k rpm when lifting off the throttle. Mainly when just starting for the first 15mins. .... Wouldnt call it a burble more like a light rumble.
Perhaps the valves moving or vibrating at that rev window??
cheers
J
kaisersolsay
Post by kaisersolsay » Sat Sep 22, 2007 12:31 pm
Pictures of my rear boxes without the acutators!!
Dom81
Post by Dom81 » Sat Sep 22, 2007 6:42 pm
Add me to the list too - not driven it yet, but the job's done...
Thanks to all
2007 Daytona RS4 Avant
pippyrips
Re: RE: Re: RE: Re: stuck?
Post by pippyrips » Sat Sep 22, 2007 7:59 pm
Scoobysnack wrote:De-Acutated for about 600miles....... So does anyone get any booming aboout 3k rpm when lifting off the throttle. Mainly when just starting for the first 15mins. .... Wouldnt call it a burble more like a light rumble.
cheers
J
Yes, though i did get it before the 'surgery' too. Been told it soulds awesome from outside 8)
Jezzer
Post by Jezzer » Sun Sep 23, 2007 12:36 am
I've completed the mod tonight and then drove the car a few miles and must admit I was a bit disappointed to tell you the truth. There was a slight difference in sound but nothing to wet myself over. I had the 80 ECU upgrade today when carrying out the car's first inspection service and thought the car seemed to be smoother and rev more freely but after this I carried out the valve mod and couldn't tell any real difference.
SORRY!
Misano Red RS4 B8 450 PS
Phantom Black RS4 B7 444 BHP
Ozrs4
Post by Ozrs4 » Sun Sep 23, 2007 2:42 am
Hi Jezzer. I don't think you can expect a boost in any performance. Personally, I like it for the noise (and I don't have to press S button everytime on start up unless I also want improbved throttle response) and I do feel there is less hesitation with the engine below 4000rpm. Like you said, nothing to wet yourself over. I'm not sure if the ECU ver 80 has much to do with it as well but I do hear people are not happy with the performance of the car after the upgrade...it's as if it's detuned! Mine is still on ver 50 and I'm told I don't have to do any upgrade(or ecu recall they called it) coz there aren't any when I went in a month ago (?!@@! I'm puzzled coz my car was hooked up for them to check if the ECU needed an upgrade, may be coz I'm in Aust). just my 2c. cheers.
2007 RS4 B7 - Phantom black saloon
Users browsing this forum: No registered users and 224 guests
