Show us your boost gauges !!
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
yorkie
Post by yorkie » Tue Sep 18, 2007 6:06 pm
I like the one in the center display is it an add-on or can you do it by adjusting the display settings?
I had a Rallye Golf where with a bit of fiddling with the mfa controls you could bring it up.
viperbl
Post by viperbl » Tue Sep 18, 2007 7:10 pm
yorkie wrote:I like the one in the center display is it an add-on or can you do it by adjusting the display settings?
Unfortunatly you can't do it with the on board stuff, but these guys made a device to allow you to use it.
I have just installed it, very pleased with it :)
http://www.fis-box.de/index-e.html
RS4 B5 Saloon8) with 750+ bhp :D
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Tue Sep 18, 2007 8:37 pm
How much did it cost, and was it pretty straight forward to fit?
What else does it offer?
Virdee Autos ~ 07950-526592
viperbl
Post by viperbl » Tue Sep 18, 2007 8:44 pm
R33V-Spec wrote:How much did it cost, and was it pretty straight forward to fit?
Did not take me long to fit, plugs into your stereo, so that needs to be pulled out, and then a cable onto the stearing wheel (take control of one of the top of the rocker switch). Not done the oil temp part yes as it replaces the current sump plug so not going to do that until I need to change the oil. That will need routing through the firewall (ECU box).
The maker, Andreas has been very helpfully answering questions etc.
It gives you Oil temp, boost pressure, speed, batt voltage. It also has alarms etc, ie oil temp too high, or boost pressure too high. It can also be plugged into the Valentine One radar detector if you have one ...
mattfinn
Post by mattfinn » Tue Sep 18, 2007 10:01 pm
Whats the price of these?? had a quick shufters on their website but its all in German!!
viperbl
Post by viperbl » Tue Sep 18, 2007 10:12 pm
mattfinn wrote:Whats the price of these?? had a quick shufters on their website but its all in German!!
I know, not the easist to navigate!!
228 Euro http://www.cxi-europe.com/shop/
Email Andreas on info at zusatzinstrumente.de, he is very helpfull
UKS4APR1
Post by UKS4APR1 » Tue Sep 18, 2007 11:44 pm
MarkB wrote:
UKS4APR1 wrote:And backlight is red, needle is white
That's spot on, where did you get that gauge?
It's made by OMORI who also make them with "AWE" logo for AWE.
Available in mechanical or electrical versions in bar or psi. Lighting (LED) is multicolour selectable.
My model is MCO-016-BFC Link here.... http://www.omorimeter.co.jp/english/cataloge-fc7.html
I sorced mine through Omori Nordic in Sweden, bit pricey but I wanted a perfect match, looks like OEM
www.omori.se
okkim
Post by okkim » Wed Sep 19, 2007 1:21 pm
Here is mine:
docurley
Post by docurley » Wed Sep 19, 2007 2:33 pm
Here's my set-up but you can get the ones that replace the top of the steering colum and have a pod built in to that.
Blue_Thunder
Post by Blue_Thunder » Sun Jan 06, 2008 7:40 pm
Has anyone fitted one of these?
Think it matches the look of the S4 nicely, especially as I have the carbon trim. Looks fairly inoffensive and comes in at around £120, much cheaper than some of the more traditional offerings.
Ads4
Post by Ads4 » Sun Jan 06, 2008 8:02 pm
Does it come with a vent attachment or does it need a bit of chopping :D
Adam.
MRC B5 S4 Avant.
BRETTCOLLINS
Post by BRETTCOLLINS » Sun Jan 06, 2008 9:31 pm
Blue_Thunder wrote:Has anyone fitted one of these?
this is what i am fitting to my car at the moment
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Blue_Thunder
Post by Blue_Thunder » Sun Jan 06, 2008 9:35 pm
Ads4 wrote:Does it come with a vent attachment or does it need a bit of chopping :D
You need to get your own chopper out I think.
Blue_Thunder
Post by Blue_Thunder » Sun Jan 06, 2008 9:37 pm
Another alternative which looks quite attractive is the Timex III (http://carbling.com.au/component/page,s ... /vmcchk,1/) with multi-changeable light schemes (ie: same gauge can suit the S4 or RS4).
They work out about £60 from Oz, but i'm waiting to hear back on the shipping costs.
BRETTCOLLINS
Post by BRETTCOLLINS » Sun Jan 06, 2008 10:08 pm
Had a custom A pillar panel made with double pod. top hole has boost gauge and the bottom has wide band air/fuel.
MING BLUE AUDI S4
Car is on Lock down
Users browsing this forum: No registered users and 113 guests
