Show us your boost gauges !!
RE: Show us your boost gauges !!
Here's mine - trouble is it won't suit the S4 due to the fact that the needle colour and backlight are different, but at least it show you where you can stick it
[img]modules/pnCPG/Coppermine/albums/userpics/10231/boost.jpg[/img]
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
not that bad to fit..take a vacumm feed from the pipe that feeds the fuel pressure reg then run the gauge pipe alone the bulkhead and into the ECU box through a slit cut in the rubber..
then remove the vent feed the hose into the back of the heater duct and connect into the new gauge..take a feed from the fuse box for the illumination when the ignition is put on..
hope that help..otherwise just read the destuctions that come with the new unit...
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
Welcome to the site
Take a look at this link, its the fitting instructions for the AWE gauge: http://www.awe-tuning.com/media/pdf/ventgauge.pdf
Users browsing this forum: No registered users and 61 guests
