The surge is mainly from the throttle bodies opening from 50-60% to 100% at 5000-5500K in the first 3 gearsRedRobert wrote:Holy Sh!t.
This is very interesting. This makes sense to me as I see my car having a "surge" of power up the gears at around 5,500 rpm all the way to 8,000rpm - that must be the valves opening?
At idle I could see them open, but had no idea they closed again. So I assume that the hose disconnected leaves the valves open all the time, rather than shut, or is there a procedure to ensure you disconnect the pipe when the valve is open etc etc?![]()
So it seems bullet proof for an idoit like mePippyRips, if you do it can you reply with your thoughts? Might give this a go at the weekend. Any things to be careful of rather than clamping and covering? Again, longer term effects?
Cheers!!
Ró
Much better
Pics? More details on the bolts?I-want-an-RS wrote:What my mate done was cut the pipe in half and then got 2 small bolts for each side, put them up the pipes and used 2 little clamps that he got from a VW dealer that are used as the fix for the rear window washer pipe comming apart from where it conects to the washer nozzel in the hatch.
- alex_123_fra
Does this have potential to cause any damage? Would the running of the car be affected by flap back-pressure, hence resulting in problems when removing this back-pressure at low revs?
Also, would the dealers make a fuss about it?
If not, sign me up. I'd love to know how to do it with some pictures maybe as I'm even more of an idiot than most when it comes to spanners and screw drivers.
Current: C7 RS6 - Black, VW Passat CC R36 - Black, Freelander 2 - Black
Sold: 911 C4S (991) - Black, Panamera Turbo ('11) - Carrera White, Nissan GT-R - DMG, B8 S4 - Phantom Black, B7 RS4 - Daytona grey saloon, Noble M400, Golf R32, Evo VIII MR, M3, Cooper S, Civic Type-R, BMW 120D (black), Mazda 6 MPS
See Here http://www.rs246.com/index.php?name=PNp ... 3&start=15alex_123_fra wrote:Does this have potential to cause any damage? Would the running of the car be affected by flap back-pressure, hence resulting in problems when removing this back-pressure at low revs?
4th post down
- alex_123_fra
Thanks t_urbo. So us lot with standard cars may run lean if we disconnect the flaps and let them open all the time, unless we remap to take this into account (like Jeroen).t_urbo wrote:See Here http://www.rs246.com/index.php?name=PNp ... 3&start=15alex_123_fra wrote:Does this have potential to cause any damage? Would the running of the car be affected by flap back-pressure, hence resulting in problems when removing this back-pressure at low revs?
4th post down
That's kind of put me off it now
- Scoobysnack
- 1st Gear
i've thought about this running lean issue if the flaps are open............. and i dont agree...... for 2 reasons..
- the Milltek running lean issue, wasnt that on a car with the full system and replaced cats.?? i.e a better flowed exhaust system , less restictive cats and no flaps? this would a big differnece. I remember having my Scoobie and AMG cars removed centre section and the flow didnt really effect the AFR that much. Whebn i went to the full system and cats massive differnece,
- the flaps are only restiricting one opening on each side at low revs i.e less than 5500. Isnt the fueling iisue on most (but not all ) cars at the higher revs . Above this Audi already open them so no issue up to 8250rpm
discuss
J
discuss
J
- Scoobysnack
- 1st Gear
- Scoobysnack
- 1st Gear
There is no risk of damage, its only an exhaust. What is really surprising about the RS4, is that with them disconnected (i.e. valves remain fully open at all times) the car drives much more smoothly and progressively, gives better MPG and doesn't sound much louder (certainly from within the cabin). It just sounds more characterful and fun.
That's what's really daft about it, with valves disconnected it feels a much better all-round car - with no downsides whatsoever.
p.s. EVO's long termer used a standard exhaust, and now my car behaves 'exactly' as it did. I'm really glad I chanced upon this discovery.
Users browsing this forum: No registered users and 508 guests
