Give me a ring I have one you can try if you dont like it send it back, bet you will keep it.
@ Philip, I will call you now!
... yep - I bet you'll keep it too.
Okay. One of the things I've heard about MRC custom remaps is that there's a better response on the throttle. I don't understand where this comes from, however, and one thing I thought of was that there may be a better reponse to the throttle pedal angle sensor. If the map requires the throttle angle sensor to be read for sane input, then how does messing with that input affect the map?S4TAN wrote:Doesn't affect the re-map on the ECU - all the SB does is tell the ECU that your throttle pedal signal value is greater than it actually is -
... [cut ] ...
- end result is that the throttle has more attack and gets to the 100% point earlier in it's physical traverse than normal.
Users browsing this forum: No registered users and 39 guests
