So, what do I replace it with? It's 5pm on a Sunday, so Halfords has just shut.
Do I use a teeny bit of washing up liquid and a lot of water, or do I leave the rest of the car until tomorrow, and come home via halfords for more lubricant?
Just running out of detailing clay lubricant...
RE: Just running out of detailing clay lubricant...
Never use washing up liquid!
Best thing to use would be your usual car shampoo, just as effective as the clay lube and much cheaper too.
jac-in-a-box
- 1st Gear
Why "never use washing up liquid"?!
I've been known to use a splash or two when needed...it works and it won't harm the car
An excerpt from the detailingworld forum . . .
"A shampoo should contain no harsh detergents if you are washing a car that you have spent many hours polishing, sealing and waxing. Harsh detergents strip wax straight off the paintwork leaving your paint surface dried out and unprotected.
Fairy Liquid is therefore a big no no for washing cars."
jac-in-a-box
- 1st Gear
Re: RE: Just running out of detailing clay lubricant...
Indeed, you're correct!Peakz wrote:An excerpt from the detailingworld forum . . .
However; if claying, your aim is to remove as much crud as possible from the paint prior to polishing, waxing etc.
I'd go as far as to suggest that using an aggresive detergent will actually help the claying process.
Once your car is fully protected, then a mild and gentle shampoo is recommended to preserve the integrity of your sealed surface....which is why I recommend Johnson Baby Bath as the perfect post-wax shampoo.
Hit Tesco's on a good day and you might find a "buy one get one free" deal on the go - points too!
Try it, it's good stuff and it will save you from spending your hard earned in "retailing world" on all these boutique shampoo's
(edited for spelling)
- ChipHazzard
RE: Re: RE: Just running out of detailing clay lubricant...
I did hear some where that the meg's quick detailer is a drop of car shampoo & water and it seems to work ok as I tried it on the wifes car a few weeks back
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
hmmm. thanks all.
Goodwood green RS4, previously owned by jeffw
Hey Dave, the Johnson's Baby Shampoo works a treat.
Know what you mean reference the "boutique" detailing paraphernalia . . .
